error in reconstructParMesh after successfully running snappyHexMesh |
September 21, 2016, 06:24 |
Hello, I am facing error inreconstructParMesh. I have successfully run snappyHexMesh for 36 ranks on the same node.
Following is the error that I am getting in reconstructParMesh: --> FOAM FATAL ERROR: bad size -1603598588 From function Foam::List<T>::List(int) [with T = int] in file lnInclude/List.C at line 82. FOAM aborting #0 Foam::error:: printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::CompactIOList<Foam::face, int>::writeData(Foam::Ostream&) const at ??:? #3 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const at ??:? #4 Foam::CompactIOList<Foam::face, int>::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const at ??:? #5 Foam:: objectRegistry::writeObject(Foam::IOstream::stream Format, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const at ??:? #6 Foam::fvMesh::write() const at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib64/libc.so.6" #9 ? at ??:? I do have 500GB memory on my node. |
reconstructparmesh, snappyhexmesh |
[snappyHexMesh] Running snappyHexMesh after mergePatchPairs | deji | OpenFOAM Meshing & Mesh Conversion | 1 | September 19, 2020 15:33 |
motorBike running snappyHexMesh in parallel? | klausb | OpenFOAM Running, Solving & CFD | 0 | December 5, 2011 19:58 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 10:38 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
