Constant velocity fiield - Zalesak Disk
Old   September 20, 2016, 14:16
Default Constant velocity fiield - Zalesak Disk
Giovanni
gio3 is on a distinguished road
Hello everyone,
I have just started to use interFoam. I have few experience with OpenFOAM but I'm a yet beginner.
I would like to run the Zalesak slotted disk problem which requires a constant velocity field.
Particularly the velocity field is position dependent, the expression is
u_x = -2 \pi y
u_y = 2 \pi x
I tried to use fvOption, using as type meanVelocityForce, but i think that in this way is only possible to add a value to the velociity field (the Ubar value), non an expression.
Any suggests?
Thank you in advance,
Giovanni
gio3 is offline   Reply With Quote
Old   May 16, 2018, 22:29
Qi Xueyu
winsway is on a distinguished road
do you realize the Zalesak slotted disk? i face the same problem with you. if you slove it ,could you share it with me? thank you very much.
winsway is offline   Reply With Quote
Old   June 3, 2018, 02:16
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You can use funkySetFields to set your velocity profile:
https://openfoamwiki.net/index.php/C...funkySetFields
If you set momentumPredictor entry to no in fvSolution file, the initial velocity profile you set is kept unchanged.
[Personal]
fumiya is offline   Reply With Quote
interfoam, velocity field, zalesak
LES and TKE calculations MST Main CFD Forum 3 May 30, 2016 07:26
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY everest20 FLUENT 1 July 13, 2015 09:35
velocity residuals stay constant izumi11 FLUENT 0 March 11, 2010 03:11
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
