September 4, 2016, 18:07 |
Internal field boundary condition confusion
annn
Rep Power: 10 |
I am confused with the concept of the internal field and what value to assign it with in the dictionaries,
I read that it is the everything but the border (boundary) of a face, but then if the inlet had one value and the outlet had another wouldn't both of their internal fields be the same since there is no way to distinguish the internal feild of an outlet to an inlet? Just as an example to see if I am getting this correct, in the velocity dictionary say the inlet was starting at a velocity of 5m/s and the outlet was 10m/s but I set the internal field as 0m/s what does this mean? the fluid is moving at 5m/s at the boundary of each cell of the inlet and at zero in the middle of the face? |
September 5, 2016, 06:12 |
Michael
Rep Power: 10 |
From what I understand (I'm relatively new to OpenFOAM myself), an external patch such as an inlet or an outlet is simply considered to be the cells on the boundary or 'outside' of the geometry. In the 0 folder you specify the initial conditions and boundary conditions of your case, so in your example the initial timestep (0) would show all of the cells on the outside of the geometry belonging to the inlet patch having a velocity of 10m/s in whatever direction you specified, all of the cells on the boundary belonging to the outlet patch having a velocity of 5m/s and all the cells in between having a velocity of 0.
Each cell can only have one value for each field (U, T, p, etc.) so it doesn't make sense to talk about the border of a cell having a different value to the middle of a cell. Of course once you run the simulation all of the internal field values will (hopefully) change, which you will see if you ever look at a computed timestep, it has a list of values for U rather than just one internal field value that applies to every cell. Also it's probably worth mentioning you usually shouldn't specify a velocity at the outlet as well as the inlet, as your case becomes overspecified and most likely won't run. -Michael |
September 6, 2016, 06:25 |
larmes
Rep Power: 10 |
but do you think that fixing a value for the pressures at the inlet and outlet and having te velocity be determined from the pressure might be over defining the situation?
September 6, 2016, 07:58 |
Michael
Rep Power: 10 |
It depends on your assumptions, i.e. whether you're assuming compressible or incompressible flow. Have a look at this thread:
http://www.cfd-online.com/Forums/mai...condition.html |
boundary condition u, internal field |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
How can I update the boundary condition for a field using another field value? | h_fathi | OpenFOAM Running, Solving & CFD | 0 | November 2, 2015 04:39 |
Time dependant pressure boundary condition | yosuke1984 | OpenFOAM Verification & Validation | 3 | May 6, 2015 07:16 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 05:13 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 07:49 |
