"killed" advice with no error explanation
Old   September 4, 2016, 07:38
Default "killed" advice with no error explanation
Aldanu is on a distinguished road
Hi everybody,
I have a problem with a heat exchanger I meshed with ansys. It's made of three parts: a central cylinder representing air, a surrounding alluminium layer and a CO2 layer surrounding alluminium. Unfortunately, when trying to separate these regions in openfoam with the command splitMeshRegions -cellZones -overwrite , the process gets killed but does not give any error advice to explain what the problem is. Thinking it could depend on the fact that the mesh was too fine, I tried to use a shorter (10 cm) and coarser version of this exchanger, and the process worked with no problems (the original exchanger is 2.64 m long). Still, I have to mesh the original exchanger and I haven't fully understood the problem. I'd really appreciate your help, I'll also attach what the terminal says
pepito@debvbox:~/OpenFOAM/pepito-3.0.1/run/multiRegionHeaterRadiation$ splitMeshRegions -cellZones -overwrite
| \\ / O peration | Version: 3.0.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 3.0.1-d8a290b55d28
Exec : splitMeshRegions -cellZones -overwrite
Date : Sep 04 2016
Time : 11:27:17
Host : "debvbox"
PID : 5366
Case : /home/pepito/OpenFOAM/pepito-3.0.1/run/multiRegionHeaterRadiation
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Creating single patch per inter-region interface.
Trying to match regions to existing cell zones.
Number of regions:3
Writing region per cell file (for manual decomposition) to "/home/pepito/OpenFOAM/pepito-3.0.1/run/multiRegionHeaterRadiation/constant/cellToRegion"
Writing region per cell as volScalarField to "/home/pepito/OpenFOAM/pepito-3.0.1/run/multiRegionHeaterRadiation/0/cellToRegion"
Region Cells
0 369600
1 166320
2 535920
Region Zone Name
0 0 aria
1 1 alluminio
2 2 co
Sizes of interfaces between regions:
Interface Region Region Faces
Reading volScalarField alphat
Reading volScalarField nut
Reading volScalarField p_rgh
Reading volScalarField cellToRegion
Reading volScalarField T
Reading volScalarField k
Reading volScalarField omega
Reading volVectorField U
Adding patches
Adding patches
Region 0
Creating mesh for region 0 aria
Testing:"/home/pepito/OpenFOAM/pepito-3.0.1/run/multiRegionHeaterRadiation/system/aria/fvSchemes"
Writing dummy "aria/fvSchemes"
Writing dummy "aria/fvSolution"
Killed
Aldanu is offline   Reply With Quote
Old   April 8, 2020, 21:36
Question Issue still exists
Sai Guruprasad Jakkala
saiguruprasad is on a distinguished road
Facing the same issue, did you find any fix for this?
saiguruprasad is offline   Reply With Quote
Old   April 10, 2020, 14:31
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
any reproducible example? preferably with a tutorial?
HPE is offline   Reply With Quote
Old   April 10, 2020, 16:14
I have sorted this problem out.
When I export the mesh from ICEMCFD, I make sure that the two-sided walls are given the interface boundary condition. This makes sure that OpenFOAM is able to identify them as interface and creates the solid-fluid interface.
killed, openfoam
Need x Advice ChukerSweet OpenFOAM Running, Solving & CFD 0 June 13, 2014 14:15
System Build Advice for FEA cycleback Hardware 1 February 8, 2013 21:53
Advice for a Beginner Dave442 ANSYS Meshing & Geometry 5 September 16, 2011 08:03
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 06:16
advice needed! Filip Main CFD Forum 2 April 26, 2002 16:27
