SnappyHexMesh not creating cellzones
Old   September 2, 2016, 06:24
Default SnappyHexMesh not creating cellzones
carno
Carno is on a distinguished road
Dear All,
I am trying hard and checking different options to create a cellzone in the mesh. It is not at all creating the cellzone. Below is the dict.
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
#includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg"
castellatedMesh on;
snap            off;
addLayers       off;
geometry
    fixed.stl
        type triSurfaceMesh;
        name fixed;
        regions
           /* <inletPatch>  { name inlet; }
            <outletPatch> { name outlet; }
/*    rotatingZone.stl
        name rotatingZone;
    rotating.stl
        name rotating;
    rad.stl
        name rad;
castellatedMeshControls
    features
        /*{ file "fixed.eMesh";        level 1; }
        { file "rotating.eMesh";     level 1; }
        { file "rotatingZone.eMesh"; level 1; }
    refinementSurfaces
        fixed
            level       (1 1);
            patchInfo   { type wall; }
            inGroups    (fixed);
            regions
                <inletPatch>
                    level (2 2);
                    patchInfo
                        type patch;
                        inGroups (inlet);
                <outletPatch>
                    level (2 2);
                    patchInfo
                        type patch;
                        inGroups (outlet);
/*       rotatingZone
            level       (1 1);
        rotating
            level       (1 1);
            faceZone    arotating;
            cellZone    arotating;
            cellZoneInside  inside;
            boundary    internal;
        rad
            level       (1 1);
    refinementRegions
        rotating
            mode inside;
            levels ((1E15 2));
    locationInMesh (10 10 10); // Offset from (0 0 0) to avoid
                                     // coinciding with face or edge
snapControls
    explicitFeatureSnap    true;
addLayersControls
    layers
        "(rotating|fixed)"
            nSurfaceLayers 2;
    relativeSizes       true; // false, usually with firstLayerThickness
    expansionRatio      1.2;
    finalLayerThickness 0.5;
    minThickness        1e-3;
//  firstLayerThickness 0.01;
//  maxThicknessToMedialRatio 0.6;
meshQualityControls
//    minTetQuality -1e+30;
writeFlags
    scalarLevels
    layerSets
    layerFields
mergeTolerance 1e-6;
PLease help!
Carno is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[snappyHexMesh] proble of creating layers with snappyHexMesh comingdaytime OpenFOAM Meshing & Mesh Conversion 3 May 24, 2018 07:18
[snappyHexMesh] SnappyHexMesh .stl Jochem OpenFOAM Meshing & Mesh Conversion 10 September 23, 2016 05:26
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[snappyHexMesh] snappyHexMesh after extrudeMesh / Creating background mesh with extrudeMesh pythag0ra5 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2013 10:10
