August 29, 2016, 02:11 |
Changing inlet BC
carno
Rep Power: 17 |
Hi All,
I want to change the inlet BC (from 20 m/s to 50 m/s) and use the previous results. Everything else is exactly the same, i.e. mesh, BC types etc. I know the results of 20 m/s case should be mapped on the new case. Code:
mapFields <source path> -consistent -sourceTime latesttime Thanks |
August 29, 2016, 02:25 |
Rep Power: 12 |
You can modify the U-file in your latest time directory (change the inlet velocity) and adapt your controlDict (startFrom latestTime). Donīt forget to choose an appropriate endTime in your controlDict.
By doing so you are able to resume the simulation with a different inlet velocity. |
August 29, 2016, 02:32 |
carno
Rep Power: 17 |
Thanks.. I will give you a try..
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
[swak4Foam] Trouble setting groovyBC interFoam Inlet BC | mgdenno | OpenFOAM Community Contributions | 4 | July 1, 2012 08:16 |
How to set up the inlet boundary condition for a low pressure case? | beastieboys6 | FLUENT | 3 | April 10, 2012 22:46 |
Changing area with a random value of pressureinlet | M-Ray | FLUENT | 0 | May 16, 2008 02:48 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
