Diameter varying slip condition on wall , 2d pipe flow
Old   August 25, 2016, 15:54
Default Diameter varying slip condition on wall , 2d pipe flow
Giannokostas Konstantinos
k.giannoko is on a distinguished road
Dear All,
I simulate a 2d poiseuille flow. I want to impose a wall slip boundary condition at the main direction of flow (z-direction). This slip condition is varying with tube diameter. From a quick search, I found that there are two main ways to implement this. Firstly, if you make your own boundary condition and secondly by using the codedFixedValue command. The pipe is not straight and the radius is different from point to point.
The condition is something like that:
Uz = f(R(z))* dUz/dy , where f() is function of local R and R(z) is radius function of z-direction
Uy = 0
Ux = 0
How can I implement such a boundary condition?
Any help is appreciated ,
K.G
k.giannoko is offline   Reply With Quote
codedfixedvalue, pipe flow, slip condition, space dependent terms
Surface Integrals of Species Mass Flow to Wall Incorrect koad FLUENT 4 January 12, 2016 17:38
How is the heat transfer calculated with slip wall condition? Meng Kong Main CFD Forum 9 December 3, 2015 19:50
Slip flow boundary condition on wall using UDFs mahdi haddad FLUENT 1 November 11, 2014 07:13
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
