Axial Fan is rotating - BC's at Inlet/Outlet?
Old   August 9, 2016, 06:14
Question Axial Fan is rotating - BC's at Inlet/Outlet?
Justin Wiegmann
SirIsaac90 is on a distinguished road
Hello Foamers,
I am struggling.. I have not found a satisfying solution
I have an axial fan inside a domain. The Inlet and Outlet have some different dimensions.
The fan has a specific rotational speed.
It is simulated compressible with rhoSimpleFoam and MRF.
I saw some threads, where it was written that:
p-->
inlet: totalPressure
outlet: fixedValue
But I can not believe that. If I know the pressure in the atmosphere, let's say: 101325 Pa.
At the Outlet, the static pressure should decrease.
So, I would say
p-->
outlet: totalPressure
Both totalPressure with p_tot = 101325 Pa, correct? Can anybody tell me whether this is the correct way to do it?
Then, this would lead to a static pressure which is less than 101325 Pa (depending on the velocity value).
Thank you!
Regards
JW
SirIsaac90 is offline   Reply With Quote
Old   September 8, 2016, 14:17
Omar jumaah
jumaah is on a distinguished road
hi, try this video
https://www.youtube.com/watch?v=KFrZoDWUC5s
I hope it will help.
Jumaah
jumaah is offline   Reply With Quote
A question about a simple ceiling fan simulation (no inlet/outlet BCs) Tellur STAR-CCM+ 3 June 9, 2017 09:34
Interpreting streamlines of a rotating fan. danbence Visualization & Post-Processing 1 April 8, 2014 11:13
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
Axial fan or blower cooling a hot object with recirculation mariconeagles96 CFX 4 April 18, 2012 09:41
axial flow in counter rotating ducted fan Vishu FLUENT 4 January 13, 2004 18:52
