topoSet messes up SlaveCells of faceZoneSets
Old   August 2, 2016, 11:24
Default topoSet messes up SlaveCells of faceZoneSets
Patrick Kastner
kostnermo is on a distinguished road
Hello everybody,
I am trying to assess mass flows through windows of a building.
My geometry looks like this (you can't see the whole domain but this is essentially what you need to know): https://postimg.org/image/6wkb4w6h3/
So I basically have a row of windows along two facades of a building/room and want to simulate the massflow through this geometry. I am therefore meshing inside as well as outside.
Depicted in yellow, you can see the faceSets (windows) which I create by using a topoSetDict. I use blockMesh in combination with snappyHexMesh for meshing my geometry.
Now, after executing topoSet I receive a cell id "-1" at the bottom of all of my slave cells which I later need for swak4Foam.
Excerpt from the bottom of contant/polyMesh/sets/window1SlaveCells
1540086
1359863
1359865
1540090
-1
Excerpt of topoSetDict:
        name window1;
        type faceZoneSet;
        action new;
        source searchableSurfaceToFaceZone;
        sourceInfo
                surface triSurfaceMesh;
                name "window_l.stl";
        name window1SlaveCells;
        type cellSet;
        action new;
        source faceZoneToCell;
        sourceInfo
                name window1;
                option slave;
This, of course, causes an error when I try to run the simulation.
[0]
[0] --> FOAM FATAL ERROR:
[0] Illegal content -1 of set:window1SlaveCells of type cellSet
Value should be between 0 and 356166
[0]
[0]     From function topoSet::check(const label)
[0]     in file sets/topoSets/topoSet.C at line 200.
[0]
FOAM parallel run aborting
If I manually remove those "-1" cell ids and change the cell number accordingly, I am able to again run the simulation. However, it is quite tedious to do this every time I change the geometry.
Commands I used up until this issue occurres are:
blockMesh
surfaceFeatureExtract
snappyHexMesh
checkMesh (mesh is ok)
topoSet
simpleFoam
Does anybody have an idea what I am doing wrong or how to solve this issue?
Thank you for your time,
Patrick
OF301-d8a290b55d28
Ubuntu 16.04
kostnermo is offline   Reply With Quote
Old   August 14, 2016, 17:00
Patrick Kastner
I was able to narrow down the issue now. The problem arises when I change the normal vector of the surface in Rhino. I do this to have consistency later in the mass flows by swak4foam.
Is there a way to do this with OF as well?
faceset, facezone, slavecells, swak4foam, toposet
topoSet tolerance akidess OpenFOAM Pre-Processing 0 September 30, 2015 12:13
[Other] cellLevel field not readable by topoSet blaise OpenFOAM Meshing & Mesh Conversion 0 June 30, 2015 05:35
[Other] topoSet Wrong number of faces. a19910112a OpenFOAM Meshing & Mesh Conversion 1 June 9, 2015 06:41
[mesh manipulation] Problem with topoSet and FaceZone creation ADGlassby OpenFOAM Meshing & Mesh Conversion 7 September 16, 2013 12:05
[snappyHexMesh] HOW to set a circular face by toposet Jessica OpenFOAM Meshing & Mesh Conversion 2 September 12, 2013 21:54
