[swak4Foam] groovyBC - inlet profile at complex terrain
Old   July 28, 2016, 03:58
Default groovyBC - inlet profile at complex terrain
Jan Potac
potac is on a distinguished road
I have defined a logarithmic velocity profile at domain over a complex terrain using groovyBC as
    inlet
        type            groovyBC;
        variables "Uref=$Uref;Zref=$Zref;z0=$z0;kappa=$kappa;Ufr=Uref*kappa/log(Zref/z0);minz=min(pts().z);WD=$WD;";
        valueExpression "vector(Ufr/kappa*log(((pos().z)+z0)/z0)*cos(WD), Ufr/kappa*log(((pos().z)+z0)/z0)*sin(WD), 0)";
        value           uniform (0 0 0);
However in my results, the profile is not relative to the elevation of the bottom edge. In other words my profile does not start from the bottom edge. When I apply this on pitzDaily case with inlet not starting at 0 coordinate, it works fine. What am I missing here? Thanks.
potac is offline   Reply With Quote
Old   December 20, 2016, 20:21
Mitchell Baum
Mitchell Baum is on a distinguished road
Hi Potac,
I'm experiencing a similar issue where I'm trying to impose a velocity profile at the model inlet in accordance with fitted field data. Ideally, I would like to implement the profile uniformly over the patch, however with the slope of the lower boundary I encounter issues.
Have you made any further progress since your last post?
Kind regards,
Mitchell
Mitchell Baum is offline   Reply With Quote
Old   January 3, 2017, 20:18
Mitchell Baum
Hi Potac,
I am still unsure about how your implementation works in pitzDaily, however I have since achieved my desired inlet BC. My issue was simply resolved by subtracting the slope from my desired velocity profile (7th order Gaussian fit).
Before:
    Inlet
		type            groovyBC;
		variables	(
				"a1= 0.1828;"
				"b1= -21.15;"
				"c1= 4.2;"
				"a2= 0.1829;"
				"b2= -31.27;"
				"c2= 3.851;"
				"a3= 0.001014;"
				"b3= -28;"
				"c3= 0.02724;"
				"a4= -0.1166;"
				"b4= -15.38;"
				"c4= 2.68;"
				"a5= 0.04652;"
				"b5= -10.67;"
				"c5= 2.141;"
				"a6= 0.1419;"
				"b6= -26.29;"
				"c6= 3.65;"
				"a7= 0.2606;"
				"b7= -15.25;"
				"c7= 3.469;"
				"zp= pos().z;"
				"velProfile= (a1*exp(-1*pow(((zp-b1)/c1),2)) +
                                a2*exp(-1*pow(((zp-b2)/c2),2)) +
                                a3*exp(-1*pow(((zp-b3)/c3),2)) +
                                a4*exp(-1*pow(((zp-b4)/c4),2)) +
                                a5*exp(-1*pow(((zp-b5)/c5),2)) +
                                a6*exp(-1*pow(((zp-b6)/c6),2)) +
                                a7*exp(-1*pow(((zp-b7)/c7),2)));"
		valueExpression "-1*velProfile*normal()";
		value           uniform (0 0.151 0);
After:
    Inlet
		type            groovyBC;
		variables	(
				"a1= 12.5;"
				"b1= -31.83;"
				"c1= 9.766;"
				"a2= -12.26;"
				"b2= -31.87;"
				"c2= 9.601;"
				"a3= 0.004232;"
				"b3= -26.65;"
				"c3= 0.3996;"
				"a4= -1.862;"
				"b4= -14.29;"
				"c4= 3.392;"
				"a5= 1.95;"
				"b5= -14.27;"
				"c5= 3.458;"
				"a6= -0.1094;"
				"b6= -25.46;"
				"c6= 5.007;"
				"a7= 0;"
				"b7= -17.9;"
				"c7= 0.01037;"
				"zp= pos().z;"
				"xp= pos().x;"
				"slopeEq= 0.01543*xp -1.04256;"
				"velProfile= (a1*exp(-1*pow(((zp-slopeEq-                     b1)/c1),2)) +
                                a2*exp(-1*pow(((zp-slopeEq-b2)/c2),2)) +
                                a3*exp(-1*pow(((zp-slopeEq-b3)/c3),2)) +
                                a4*exp(-1*pow(((zp-slopeEq-b4)/c4),2)) +
                                a5*exp(-1*pow(((zp-slopeEq-b5)/c5),2)) +
                                a6*exp(-1*pow(((zp-slopeEq-b6)/c6),2)) +
                                a7*exp(-1*pow(((zp-slopeEq-b7)/c7),2)));"
If you have not yet reached a solution, perhaps you could apply a similar method and fit a curve to match your terrain and execute a similar process?
Kind regards,
Mitchell
How to apply variabe roughness, e.g. to complex terrain? Fridolin OpenFOAM Running, Solving & CFD 3 August 12, 2020 16:09
[swak4Foam] parabolic velocity profile with fluctuations (groovyBC?) newOFuser OpenFOAM Community Contributions 17 July 15, 2013 18:27
help with boundary profile in pressure inlet quiqui FLUENT 21 June 18, 2013 13:55
How to apply an outlet velocity profile to another inlet? siw FLUENT 4 April 10, 2013 12:19
Pulsatile profile at inlet Josyula Fluent UDF and Scheme Programming 4 May 6, 2012 11:09
