uniformFixedValue
Old   July 9, 2016, 07:17
Unhappy uniformFixedValue
Jack_Landis's Avatar
Jack_Landis is on a distinguished road
Dear all,
I'm using openFoam 2.2.1 on Ubuntu 15.10 and Paraview 3.12.0. I have a 2D square channel with a liquid slug patched at its center (boxToCell) surrounded by air. I want to give a boundary condition on velocity at inlet such that velocity oscillates as a cosine function. I found on the internet that I could do this using uniformFixedValue as I did.
I input this code:
inlet
    type             uniformFixedValue;
    uniformValue     table
        (0          (0                    0 0))
        (0.1        (0.002964373          0 0))
        (0.2        (0.0048932052        0 0))
        (0.3        (0.0051127001        0 0))
        (0.4        (0.0035461817        0 0))
        (0.5        (0.00074088           0 0))
        (0.6        (-0.0023232323        0 0))
        (0.7        (-0.0045757728        0 0))
        (0.8        (-0.0052298642        0 0))
        (0.9        (-0.0040570136        0 0))
        (1          (-0.0014669314        0 0))
        (1.0471975512    (0                  0 0))
where I think the first number is time and the three numbers are velocity vectors. When I launch the simulation, it gives me no error but when I try to open results in Paraview it tells me: "error reading line 48 of ../0/U: Expected a number, found ( ". Line 48 corresponds to t=0.2. Then, I can visualize volume fraction results but not velocity results.
How can I manage this problem? Am I using uniformFixedValue in a wrong way? Will this error influence my results?
Thank you a lot!
Jacopo
Omnia per ipsum facta sunt,
et sine ipso factum est nihil,
quod factum est
Jack_Landis is offline   Reply With Quote
multiphase, paraview, uniformfixedvalue
problem with using uniformFixedValue in OF 2.1.1 amin144 OpenFOAM 3 June 29, 2016 14:22
uniformFixedValue boundary condition meth Main CFD Forum 0 November 5, 2015 00:16
[OpenFOAM] uniformFixedValue with a table -> paraview doesn't show the field nlinder ParaView 11 October 17, 2015 09:05
Boundary conditions definition using uniformFixedValue SF_ OpenFOAM Pre-Processing 0 October 14, 2015 22:06
[mesh manipulation] oscillatingInletACMI2D with dynamicMotionSolverFvMesh Doofy_180 OpenFOAM Meshing & Mesh Conversion 0 June 11, 2015 07:28
