Boundary condition for phi field.
Old   June 7, 2016, 15:01
Default Boundary condition for phi field.
Jean Schuster
jeanbvb is on a distinguished road
Hi guys.
I'm trying to simulate a shear driven flow (Couette flow) with different temperatures between the superior an inferior boundaries, with the top wall moving an the bottom wall at rest. I'm using OpenFoam 2.4.0.
For that I'm plainning to use the buoyantPimpleFoam solver. The superior and inferior boundaries are of the type wall, and the horizontal boundaries (streamwise and spanwise directions) are of the type cyclic.
For the phi field it is needed to specify a value for the cyclic boundary condition, and I dont know the right way to set this. Setting it like the code bellow I'm able to run my case, but I think that it makes no sense setting it to uniform 0 on the cyclic boundaries.
dimensions      [1 0 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    bottomWall
       type            fixedValue;
	value 		uniform 0;
    topWall
       type            fixedValue;
	value 		uniform 0;
    sides1_half0
       type            cyclic;
        value           $internalField;
    sides1_half1
       type            cyclic;
    sides2_half0
       type            cyclic;
    sides2_half1
       type            cyclic;
    inout1_half0
       type            cyclic;
    inout1_half1
       type            cyclic;
    inout2_half0
       type            cyclic;
    inout2_half1
       type            cyclic;
Also for the Ubar configuration in the constant/transportProperties, being it a shear driven flow, it is still necessary to specify the mean flow velocity or setting Ubar to ( 0 0 0 ) would be ok?
Regards.
jeanbvb is offline   Reply With Quote
Old   June 13, 2016, 03:44
Nima Samkhaniani
nimasam is on a distinguished road
as much as i know, here the value is place holder and your assigned magnitude is irrelevant.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 14, 2016, 10:03
Jean Schuster
Hi Nima, indeed the results for the ciclic bc seems to be correct having a quick view of the flow in paraView.
Thanks for your replly.
phi boundary condition, phi field, phi openfoam
Field value inside a boundary condition class pcaron OpenFOAM Programming & Development 14 October 17, 2022 10:40
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
