Problem with pointDisplacement in 3D
Old   May 3, 2016, 15:12
Default Problem with pointDisplacement in 3D
Alejandro Valeije
alexvaleije is on a distinguished road
Hi everyone,
I am working with a 3D simulation of the flow around a prism which moves "freely" inside a channel. "Freely" means that the prism can go up and down, but also can rotate around the Z axis (assume that the flow goes in the X direction). I am doing this with the sixDoFRigidBodyDisplacement library and a mod of pimpleDyMFoam in OF 2.2.1.
The thing is that i get some good results when I run this in 2D, but in the moment I go into 3D, the mesh twists in a way that it collapses into itself. I think that this can be related to the boundary condition I apply on the moving patches, which in 2D have the "empty" BC.
Have someone experienced something similar to that or could help me with this?
Regards
Alex
alexvaleije is offline   Reply With Quote
Old   September 25, 2018, 13:13
Zoe Yamaguchi is on a distinguished road
Any luck with the solution? I resorted to moving the whole mesh while keeping the prism fixed, instead.
Zoe Yamaguchi is offline   Reply With Quote
Old   September 25, 2018, 13:25
Alejandro Valeije
Unfortunately, no. I was trying with the 6DoF libraries attached in the new versions, but with my particular cases I haven't got any good results.
However, i think that my case may have some particularities that may lead to the failure, because I've tried with other cases with positive results, so I'm not sure of what could it be the cause.
Hope you have more luck than me. Regards,
Alex
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
