April 27, 2016, 05:44 |
T-Junction buyoancy driven flow.
Michael Olsen
Hi all,
I'm currently trying to simulate a multiphase T-Junction where the inlet is pumping air into a fluid filled channel. Like this: ..........................| outlet. | ..........................| to bulk | ..........................| liquid...| ..........................|.......... | ..........................|.......... | _______________|.......... | Velocity gas................... | Inlet .............................. | --------------------------- ..........| ...........................|......... | ...........................|......... | ...........................| .........| ...........................|.. Inlet | ...........................| from.. | ...........................|.. Bulk | ...........................| Liquid | I've set up my case by modifying the damBreak tutorial case in interFoam, and according to checkMesh, my mesh is "OK", plus, using paraFoam, my velocity inlet seems to be fine and my alpha.water phase fraction seem to be fine. However, when i go to run my case with adjustable time step, my courant number peaks and my deltaT drops (as a result) to around 1.e-7 kind of values, which seem unreasonable. What can I do to solve this, or has anyone done this type of simulation before or do they have some template code that I can use?? Just really confused as to why my case isn't running properly. |
April 27, 2016, 11:54 |
Anton Kidess
Rep Power: 30 |
Such a value is reasonable for microfluidic devices:
http://www.cfd-online.com/Forums/ope...tml#post574191
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
April 28, 2016, 15:09 |
#3 | |
Michael Olsen
Hmmmm, I looked around and it does seem reasonable according to other people simulating microfluidic flow domains. My problem is, the speed is far too slow for me (it would take several months to simulate 1 second) at that timestep; is there anything I can do to speed it up? Perhaps change the solver or something? Incidentally, I changed the dimensions of my mesh and ran the simulation, it ran in a reasonable amount of time with a timestep of around 0.005 seconds and seemed reasonable, so really it seems to be the mesh size that is my problem. Will coarsening my mesh have much effect? Or is my best bet to just change the solver? |
April 29, 2016, 01:53 |
Anton Kidess
Rep Power: 30 |
Part of your study will have to include a mesh refinement test to determine the influence on your results.
multipha, multiphase boundary, openfoam |
Impellar driven fluid flow in centrifugal pump | shivasluzz | CFX | 6 | October 6, 2015 10:00 |
LTSInterFoam and pressure driven flow | Andrea_85 | OpenFOAM | 3 | August 21, 2012 08:44 |
is there any parallel code for the famous Lid Driven Cavity flow? | gholamghar | Main CFD Forum | 0 | August 1, 2010 01:55 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 06:52 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
