Outlet with mass flow specified: temperatures diverge
Old   April 25, 2016, 09:57
Default Outlet with mass flow specified: temperatures diverge
Sarah Leenknegt
SarahLee is on a distinguished road
Dear,
I am trying to run a case with an air curtain at the entrance of a large building, including an outdoor "box" with athmospheric boundaries.
I keep seeing the temperatures at the outlet boundary diverge to unrealistic high values. The meshcheck is successfull, and further refinements have also been made, so I assume the problem is my boundary condition at the outlet. The high temperatures occur at the boundary cells at the outlet area. Already after 20 iterations, the problem starts.
I can post pictures of the geometry with mesh, when required.
The case is running with buoyantboussinesqsimplefoam and kwSST, GAMG solver for p_rgh.
My outlet BDC:
- p = fixedfluxpressure
- p_rgh = fixedfluxpressure
- T = 12 °C (in case of backflow)
- v = x 0; y 1.8; z 0 m/s
- omega = zero gradient
- k = zero gradient
- kappa, alpha, nu = calculated
Important is that I can define the mass flow at the outlet, otherwise the supplied hot air from the air curtain would just flow through the door to outside.
I would appreciate any feedback on potential errors! I have been playing around with different BDC's, but have not found a solution. Or should I look again at my mesh or something else going on with the solver?
In case relevant:
My inlet BDC:
- T = 32 °C
- v = x 0; y 0; z -6 m/s
- omega = turb mix length 0.1 m
- k = turb intensity 5 %
My athmospheric BDC:
- p_rgh = totalpressure
- T = -4 °C
- v = pressureinletoutletvelocity
Thanks a lot!
Sarah
SarahLee is offline   Reply With Quote
Old   May 10, 2016, 06:38
Sarah Leenknegt
In case it can help someone else:
The solution was to set the thermal boundary condition at the outlet to zero gradient.
buoyanboussinesqsimple, divergence of temperature, outlet bc
Plotting mass flow rate at outlet for transient simulation Rakib Fluent Multiphase 4 September 6, 2015 00:46
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 13:30
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 03:42
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
Mass flow rate in outlet Saturn FLUENT 1 October 11, 2004 10:39
