April 13, 2016, 10:40 |
Setting angle of inlet velocity.
Rep Power: 10 |
Hey all,
I'm pretty new to OpenFOAM and I've been successfully running some (2D) simulations before this post. For this new simulation i'd like my inlet velocity to come in at 0.05 m/s at an angle of 45 degrees, I have given it a go but I'm not sure if what I'm trying to do is correct and I'd like someone to have a look at my U file (bellow) to either verify or suggest a way to accomplish this task. Thanks. Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.0353 0.0353 0); boundaryField { ch1_inlet { type inletOutlet; value uniform (0.0353 0.0353 0); inletValue uniform (0.0353 0.0353 0); } ch_1blocked { type fixedValue; value uniform (0 0 0); } ch1_wall { type fixedValue; value uniform (0 0 0); } ch1_to_porous { type cyclic; } ch1_sides { type empty; } ch2_blocked { type fixedValue; value uniform (0 0 0); } ch2_outlet { type zeroGradient; } ch2_wall { type fixedValue; value uniform (0 0 0); } ch2_to_porous { type cyclic; } ch2_sides { type empty; } porous_ends { type fixedValue; value uniform (0 0 0); } porous_sides { type empty; } porous_to_ch1 { type cyclic; } porous_to_ch2 { type cyclic; } } Last edited by kareemm2; April 14, 2016 at 06:38. |
April 14, 2016, 06:09 |
Rep Power: 11 |
Hi there,
I am new to OF as well. As far as I know, there seems to be no problem with your BCs. You can always check if it's okay using Paraview before running. Are you getting any sort of error when running it? |
April 14, 2016, 06:13 |
Rep Power: 10 |
Hey, thanks for the reply, I've ran my simulation and there are no errors, I was just concerned that I may not have set up my U file to do what I wanted properly.
April 14, 2016, 06:26 |
Alex
Rep Power: 12 |
Quick reply: you're correct! Since you define U in components, your interpretation of the U file is right. You can also see it when you generate streamlines from the inlet in paraFoam.
Cheers Alex |
April 14, 2016, 06:47 |
Rep Power: 10 |
Thanks for the confirmation, but I forgot to ask; when changing the inlet velocity, was I right in changing the values internalfield, inletvalue and value for the velocity?
April 14, 2016, 07:34 |
Rep Power: 10 |
Nevermind; following Alex's advice, it seems that what I'm doing is fine. Thanks again for your help.
April 14, 2016, 09:41 |
Alex
Rep Power: 12 |
Yes, that's right.
I usually prefer to set my internalfield values to 0 at 0 and then initialize with potentialFoam. If you want to keep the intiial U for internalfield you can set the U for Inlet to Code:
type inletOutlet; value $internalField; inletValue $internalField; ~~ what I was referring to when talking about the internalField at t=0 : this is only the initial velocity at t=0 and it changes anyway. From my experience , when dealing with complex geometry or high freestream turbulence, the convergence is a little softer when initializing with U = 0 for internalField. Cheers Alex |
April 15, 2016, 06:22 |
Rep Power: 10 |
Thanks a bunch Alex, you've save me quite some time with that advice.
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 05:58 |
3-D parabolic velocity Inlet - Steady state - UDF Turbulent Flow | mohibanwar | Fluent UDF and Scheme Programming | 10 | May 18, 2015 11:34 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
boundary condition velocity inlet dont have gauge pressure setting value? | coolyihao | FLOW-3D | 0 | March 17, 2009 11:17 |
UDF paraboloid velocity inlet | Ronak Shah | FLUENT | 0 | June 4, 2003 10:44 |
