Transport model
Old   April 7, 2016, 09:09
Default Transport model
AdOo
adrieno is on a distinguished road
Hi all,
I'm facing with the eternal problem of transport model...
I said "eternal" because before posting this thread, I was looking on many older posts which has been unsolved for years now.
Like most of the older post, I was initially looking for some As and Ts coefficient, in order to run reactingFoam (without reaction) using the Sutherland model (used in the counterFlowFlame2D OpenFOAM exemple).
The thing is:
  • As I said, it is very difficult to find liable values (even just values...)
  • This Transport properties model, based on modified Euken model seems not to be very accuracy.
So concretely, how do you prepare your Transport model for your simulation ?
  • Do you manage to find the Sutherland coefficient and temperature you need for your case ?
  • Do you use the polynomial model ? (but here again, there's the question on how to find the required coefficient... I can't see the light at the end of the tunnel)
  • Do you program your own Transport model ? (I'm freaking out, you're telling me that's how you do)
  • Do you simply use the const model whithout tempting to surch any coefficient... ? (I'm sure you worth better than this one)
Thank you for your replies,
Adrien
adrieno is offline   Reply With Quote
Old   April 7, 2016, 12:18
AdOo
According https://openfoamwiki.net/index.php/Contrib/Janaf :
" In OpenFOAM the same reader, which reads the thermodynamic data of the janaf table also contains the input data of the laminar viscosity. Therefor the Sutherland formula is used, which shows a linear increasing of the viscosity depending on the temperature. The input data is hard coded and describes the temperature dependent viscosity of pure nitrogen. In a case with nitrogen as environmental gas this could be an acceptable approximation, if there are no ionization processes. "
and
" For temperatures above 10000 K the Sutherland formula is not a good approximation anymore. The beginning ionization leads to an decreasing of the laminar viscostiy. Therefor a transport model based on polynomials should be used instead. "
The question of the ability to find the Sutherland coefficients and temperatures is then still topical for those who trust on this model.
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
question about composition PDF transport model lisa_china FLUENT 3 November 23, 2014 20:59
Transitional Flow Shear Stress Transport (SST) k-omega Turbulence Model josechen FLUENT 0 July 20, 2011 17:06
DPM vs Species transport model osh FLUENT 0 August 19, 2005 23:15
About Composition PDF Transport Model cfdfans FLUENT 0 October 25, 2004 07:00
