Question on vacuum chamber
Old   April 5, 2016, 07:15
Default Question on vacuum chamber
PaoloP
paolo.pizzol is on a distinguished road
Hi all
I am in need of simulating the flow of 100 sccm of Argon inside a chamber at 5 mbar. Which solver should I use? RhoFoam or PisoFoam? How and where do I set the pressure for the chamber?
Thanks!
Paolo
paolo.pizzol is offline   Reply With Quote
Old   April 5, 2016, 08:00
akidess's Avatar
Anton Kidess
Have you checked the Knudsen number?
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   April 5, 2016, 08:16
PaoloP
Nope, I'm afraid I haven't. I just went online to calculate it, and it seems to be in the 10-5 / 10-6 range... is it helpful?
Old   April 5, 2016, 11:19
akidess's Avatar
Anton Kidess
That seems very small for a vacuum, but of course you didn't give a lot of details on your problem, so let's assume it's true, then you can use continuum mechanics. Now, determine if your density is constant and you'll know if you can use pisoFoam or not.
Old   April 5, 2016, 11:51
PaoloP
Thanks for the suggestion akidess :-)
To be a bit more specific, I have a cylindrical chamber of about 20 cm of length and 10 cm in diameter. The chamber is constantly being pumped, so it has a base pressure of about 10^-3 mbar. I know from experiments that when I inject the gas (from the centre of the base of the cylinder) the pressure raises to about 5 mbar and stays there.
I would imagine that after the initial few moments (seconds maybe?), since the pressure is constant, the gas density would also be constant.
...although I may be completely wrong :-)
Any hints?
Thanks!
Paolo
gas nozzle in vacuum chamber paolo.pizzol OpenFOAM Pre-Processing 2 January 22, 2016 12:06
Vacuum chamber gustavosimiema FLUENT 0 June 9, 2015 10:10
question about free surface-multiphase simulation rystokes CFX 3 March 31, 2011 07:37
Airflow in a chamber Issa CFX 9 January 30, 2010 17:10
Coal particles in combustion chamber Luis Filipe Fabiani CFX 2 March 10, 2009 16:37
