oopenFoam error
Old   March 29, 2016, 04:19
Default oopenFoam error
katia chekini
cyndy M is on a distinguished road
i use simpleFoam (k-epsilon model)
i run OpenFoam and after 10 or 20 iterations, an error message displays.
i want to understand why
#0 Foam::error:: printStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/opt/openfoam240/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#3 Foam:ICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) at ??:?
#4 Foam:ICPreconditioner:ICPreconditioner(Foam::l duMatrix::solver const&, Foam::dictionary const&) at ??:?
#5 Foam::lduMatrix:reconditioner::addsymMatrixConst ructorToTable<Foam:ICPreconditioner>::New(Foam:: lduMatrix::solver const&, Foam::dictionary const&) at ??:?
#6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) at ??:?
#7 Foam:: PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#8 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#10 ? at ??:?
#11 ? at ??:?
#12 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#13 ? at ??:?
cyndy M is offline   Reply With Quote
Old   March 29, 2016, 13:37
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
The error in general means diverging solution. Why your case is diverging? Nobody can tell till you post either your case, or IC/BC.
alexeym is offline   Reply With Quote
Old   March 29, 2016, 15:25
katia chekini
what do you mean by case or IC/BC??
Old   March 29, 2016, 17:27
Alexey Matveichev
By case I mean archive of your case folder. By IC/BC I mean initial and boundary conditions (i.e. 0 folder).
You see, your error message is quite generic, so to say something meaningful one needs your case description. The easiest way for you to provide this description is to post archive of the case folder. So people look at the message, maybe download archive, maybe unarchive it, maybe run it, post questions about what you even trying to simulate, and so on.
Another way is to post short description of your case, add scheme of your case with physical boundary conditions (as a picture), initial conditions (as a picture), output of checkMesh (to be sure that your mesh is OK), attach fvSchemes and fvSolution files (so people can be sure, your mesh, schemes, and solvers are consistent).
Unfortunately your message consists only of error message.
Old   March 30, 2016, 03:32
katia chekini
for my meshing i use hypermesh i don't do it with OpenFoam because i think it's harder.
here are my files: from 0 folder
for epsilon,
| \\ / O peration | Version: 2.2.2 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object epsilon;
dimensions [0 2 -3 0 0 0 0];
internalField uniform 0.35;
boundaryField
inlet
type fixedValue;
value uniform 0.35;
outlet
type zeroGradient;
parois
type epsilonWallFunction;
value uniform 0;
velocity
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (40 0 0);
outlet
type zeroGradient;
parois
type fixedValue;
value uniform (0 0 0);
pressure
FoamFile
version 2.0;
format ascii;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
}/*--------------------------------*- C++ -*----------------------------------*\
FoamFile
version 2.0;
format ascii;
object nuTilda;
dimensions [0 2 -1 0 0 0 0];
boundaryField
inlet
type fixedValue;
value uniform 0;
outlet
type zeroGradient;
parois
type zeroGradient;
parois
type zeroGradient;
kinetic energy
FoamFile
version 2.0;
format ascii;
location "0";
object k;
internalField uniform 0.06;
boundaryField
inlet
type fixedValue;
value uniform 0.06;
outlet
type zeroGradient;
parois
type kqRWallFunction;
value uniform 0;
nu
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
boundaryField
inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
parois
type nutkWallFunction;
value uniform 0;
nutilda
FoamFile
version 2.0;
format ascii;
object nuTilda;
boundaryField
inlet
type fixedValue;
value uniform 0;
outlet
type zeroGradient;
parois
type zeroGradient;
from system folder
fvsheme:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss upwind;
div(phi,k) bounded Gauss upwind;
div(phi,epsilon) bounded Gauss upwind;
div(phi,R) bounded Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) bounded Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
for fvSolutition
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-04;
relTol 0.01;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-04;
relTol 0.1;
k
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
epsilon
solver PBiCG;
tolerance 1e-04;
relTol 0.1;
R
solver PBiCG;
tolerance 1e-04;
relTol 0.1;/*--------------------------------*- C++ -*----------------------------------*\
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-04;
relTol 0.01;
U
solver PBiCG;
tolerance 1e-04;
relTol 0.1;
k
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
epsilon
solver PBiCG;
tolerance 1e-04;
relTol 0.1;
R
solver PBiCG;
tolerance 1e-04;
relTol 0.1;
nuTilda
solver PBiCG;
tolerance 1e-04;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
residualControl
p 1e-3;
U 1e-3;
"(k|epsilon|omega)" 1e-3;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
epsilon 0.7;
R 0.7;
nuTilda 0.7;
nuTilda
solver PBiCG;
tolerance 1e-04;
relTol 0.1;
SIMPLE
residualControl
p 1e-3;
U 1e-3;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
epsilon 0.7;
R 0.7;
nuTilda 0.7;
Old   March 30, 2016, 03:45
katia chekini
Here is my meshing
MESH.docx
Old   March 30, 2016, 07:21
Alexey Matveichev
1. Your mesh seems to be tetrahedral, so, please, post checkMesh output.
2. Since your mesh if tetrahedral, use leastSquares for gradient.
3. How do you calculate inlet values for k and epsilon?
4. (this is generic advise) Since your solution diverges, relax more
Old   March 30, 2016, 09:03
katia chekini
in this case I left the parameters by default...
before that i used correlations and it gave me the same result (diverging).
I tried to calculate theme with a turbulence intensity I= 0.16.Re^(-1/8)
after that,I found that this correlation is used for a fully developed pipe flow and I want to simulate a flow in an elbow. ( I guess it's not the one i have to use)
for epsilon i used: e=0.09^(3/4)*(k^(3/2)/Isc with Isc= turbulence scale=7% of the hydraulic diameter
k= (3/2)*(v*I)^2 with v=velocity
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
