harshawardhank
Rep Power: 13 ![]() |
Hello Foamers,
Is their any Derived bounary condition for inlet which conserve the mass in side the domain. Regards Harshawardhan |
Vinícius da Costa Ávila
Rep Power: 11 ![]() |
Hi, I'm no expert, but as far as I know, once the simulation is stable and stationary, the mass balance should be respected.
If you want to check it, just compute the mass inlet and oulet flows.
Vinícius dC.A. |
harshawardhank
this is for continuous process..not for not for semi-batch proess...we should keep mass inside the domain constant
Ok, so it is just like I said. dm/dt=mass.in - mass.out, you may set inlet mass rate and outlet pressure, for exemple, it depends on your case. When it converges, dm/dt=0. So mass is kept constant in the domain.
Vinícius dC.A. |
harshawardhank
yes, and for kepping mass constant inside the domain we should give inlet velocity or inlet flux as a boundary condition
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
Mass flow boundary condition | Renato. | Main CFD Forum | 0 | July 21, 2006 22:07 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
