Puya
Rep Power: 10 ![]() |
I would be grateful if anybody tells me how can I combine two different blocks that are produced in two different blockMeshDict files. I need sth as like as mirrormesh that connects the mirror of one mesh to itself, but I want it connect two blocks in two different files. Thank you |
Rep Power: 16 ![]() |
mergeMeshes should do the trick. Take a look at it. Cheers, Antimony |
Puya
thank you, do you know any example of using mergeMeshes?
This document lists a few, with usage: http://www.tfd.chalmers.se/~hani/kur...ionObjects.pdf Cheers, Antimony |
Puya
Thank you.
blockmesh |
attaching trn files | hossein_sml | CFX | 1 | August 5, 2015 19:17 |
[General] Combining Two Data Files | redui | ParaView | 3 | June 24, 2015 07:04 |
How to call FORTRAN files as UDF? | Ehsan-F | Fluent UDF and Scheme Programming | 6 | September 11, 2012 11:03 |
Writing Case and Data Files Using Journal/Scheme Files | svp | Fluent UDF and Scheme Programming | 0 | April 5, 2011 11:04 |
Problems with result files | Kasper | CFX | 5 | December 14, 2006 02:41 |
