How to calculate mass flow rate through arbitrary rectangle plane in paraview
Old   March 10, 2016, 03:15
Default How to calculate mass flow rate through arbitrary rectangle plane in paraview
Manoj
manoj_nav is on a distinguished road
Hi All,
I am trying to calculate mass flow rate at 12 HVAC vents opening. These openings are not defined as patch or face. They are interior of the domain. I want to define plane/rectangle of a give size at these opening locations to calculate the mass flow rate through them. But when I create a plane in paraview using sources > plane, the plane doesn't have nay data field - U or p.
Please help me to calculate mass flow rate at arbitrary plane in the domain. When I use slice or cut plane, it cuts through the whole domain, which I don't want.
Regards,
Manoj
manoj_nav is offline   Reply With Quote
Old   March 10, 2016, 03:16
Manoj
Sorry posted in wrong forum section. Please delete.
Calculating mass flow rate at multiphase flows Kuslo187 OpenFOAM Post-Processing 1 August 21, 2015 19:11
UDF to access interior surface to calculate mass flow rate shahjehan Fluent UDF and Scheme Programming 0 August 11, 2015 15:44
Mass flow rate boundary condition with negative values ashtonJ CFX 3 November 26, 2014 06:21
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 14:14
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 11:44
