chtMultiRegionSimpleFoam 3D problem
Old   March 7, 2016, 07:34
Default chtMultiRegionSimpleFoam 3D problem
Lucie
Lucie is on a distinguished road
I did a chtMultiRegionSimpleFoam case with radiation, convection and conduction between 4 solids and the air around. This model works fine in 2D with frontAndBack with "empty" condition, but when I did the same in 3D I have a problem. The calcul doesn't run ! There is only one iteration and only for displacement solver. The run stopped before h is calculated.
Do you know where the problem could be?
| \\ / O peration | Version: 2.3.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
/* Windows port by CFD support (www.cfdsupport.com) [based on Symscape] *\
Build : 2.3.x-819030ed51bd
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create fluid mesh for region domain0 for time = 0
Create solid mesh for region Solid1 for time = 0
Create solid mesh for region Solid2 for time = 0
Create solid mesh for region Solid3 for time = 0
Create solid mesh for region Solid4 for time = 0
*** Reading fluid mesh thermophysical properties for region domain0
Adding to thermoFluid
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
Adding to rhoFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to turbulence
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
sigmak 1;
sigmaEps 1.3;
Prt 1;
Adding to ghFluid
Adding to ghfFluid
Selecting radiationModel P1
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting scatterModel none
Selecting sootModel none
Adding fvOptions
No finite volume options present
*** Reading solid mesh thermophysical properties for region Solid1
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
equationOfState rhoConst;
specie specie;
Adding to radiations
Selecting radiationModel opaqueSolid
Adding fvOptions
*** Reading solid mesh thermophysical properties for region Solid2
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
specie specie;
Adding fvOptions
*** Reading solid mesh thermophysical properties for region Solid3
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
specie specie;
Adding fvOptions
*** Reading solid mesh thermophysical properties for region Solid4
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
specie specie;
Adding fvOptions
Time = 1
Solving for fluid region domain0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.02938802, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.008910754, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0291222, No Iterations 1
Lucie is offline   Reply With Quote
Old   March 17, 2016, 16:39
Alex
zfaraday will become famous soon enough
Hi Lucie,
You need to provide more information if you want to get some help from the forum. It is impossible to diagnose anything with the few information you gave us... You didn't even attach the error message!!!
Information such as boundary conditions, fvSolution, error message shown by the solver is usually needed in order to be able to find out what is going wrong!
Best regards,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   June 21, 2016, 06:23
Vishesh
visheshkapoor06 is on a distinguished road
please provide with the error message.
visheshkapoor06 is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
