blockMesh problem
Old   March 3, 2016, 23:48
Default blockMesh problem
Shahil
shahilc is on a distinguished road
I am working on a 2D problem (please check the attached image), where a very small heat source is placed inside of the box, with penetrating into the solid. I am facing problems in creating the blockMesh. Please advice if it is the correct way of creating a blockMesh for this case. Also, please help resolving the current error found while running the blockMesh
face 0 in patch 1 does not have neighbour cell face: 4(1 7 6 0)
blockMeshDict File:
convertToMeters 0.001;
vertices
(-505 -400 0)
(505 -400 0)
(505 150 0)
(-505 150 0)
(-505 0 0)
(505 0 0)
(-505 -400 1)
(505 -400 1)
(505 150 1)
(-505 150 1)
(-505 0 1)
(505 0 1)
(-10 0 0)
(-10 -10 0)
(10 -10 0)
(10 0 0)
(-10 0 1)
(-10 -10 1)
(10 -10 1)
(10 0 1)
(-10 -400 0)
(10 -400 0)
(-10 -400 1)
(10 -400 1)
blocks
hex (0 20 12 4 6 22 16 10) (40 80 1) simpleGrading (1 1 1)
hex (20 21 14 13 22 23 18 17) (40 78 1) simpleGrading (1 1 1)
hex (21 1 5 15 23 7 11 19) (20 80 1) simpleGrading (1 1 1)
hex (4 5 2 3 10 11 8 9) (100 50 1) simpleGrading
(0.5 0.5 0.25)
(0.5 0.5 4)
10
1
edges
boundary
maxY
type wall;
faces
(2 3 9 8)
minY
type wall;
faces
(1 7 6 0)
solidLeft
type wall;
faces
(6 10 4 0)
inlet
type patch;
faces
(10 9 3 4)
solidRight
type wall;
faces
(1 5 11 7)
outlet
type patch;
faces
(5 2 8 11)
frontAndBack
type empty;
faces
(0 4 5 1)
(7 11 10 6)
(4 3 2 5)
(11 8 9 10)
mergePatchPairs
Error in Solver
--> FOAM FATAL ERROR:
From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam:olyMesh::facePatchFaceCells(Foam::List<Foam ::face> const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const at ??:?
#3 Foam:olyMesh::setTopology(Foam::List<Foam::cellS hape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, int&, int&, Foam::List<Foam::cell>&) at ??:?
#4 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) at ??:?
#5 Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) at ??:?
#6 Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) at ??:?
#7 ? at ??:?
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? at ??:?
Aborted (core dumped)
Please check attached image
shahilc is offline   Reply With Quote
Old   March 4, 2016, 06:56
gereksiz
clktp is on a distinguished road
Have you tried to mesh the blocks separately? You may have a ordering error. I remember the error message but I can't recall when I received it.
clktp is offline   Reply With Quote
Old   March 4, 2016, 12:42
Antimony is on a distinguished road
Based on a quick look at your block definitions, I don't see any one block that has all the vertices 1, 7 6 and 0. Double check and see that the vertices that you use to define a face belong to a particular block.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   March 4, 2016, 14:51
Smile
Shahil
Hello guys,
Thanks for your quick advice. I specified the blocks separately and the mesh worked out.
The following is what I did:
minYa
type wall;
faces
(0 20 22 6)
minYb
type wall;
faces
(20 21 23 22)
minYc
type wall;
faces
(21 1 7 23)
frontAndBack
type empty;
faces
(0 4 12 20)
(20 13 14 21)
(21 15 5 1)
(22 16 10 6)
(23 18 17 22)
(7 11 19 23)
(4 3 2 5)
(11 8 9 10)
Keeping the rest of the conditions same. Thanks
[blockMesh] Problem with blockMesh and my shape TneurolF OpenFOAM Meshing & Mesh Conversion 4 June 25, 2013 14:52
Blockmesh problem with more than one block sven82 OpenFOAM Pre-Processing 1 June 4, 2013 18:08
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
