Number of cells in mesh:16000 does not equal size of cellLevel:24400 |
Rupesh
Rep Power: 10 ![]() |
Hello Everyone,
I was trying to combine SolidBodyMotion and RefineFVMesh in OpenFOAM and fortunately, i found exactly the same in the Book "The OpenFOAM Technology Primer" by Tomislav, Jens Hopken, and Kyle Mooney. But i got the following error when i tried to run test case given in a book: "Number of cells in mesh:16000 does not equal size of cellLevel:24400 This might be because of a restart with inconsistent cellLevel." I successfully compiled the class "dynamicSolidBodyMotionRefinedFvMesh" which i took from the repository available on bitbucket, but when i try to run the test case given in "Chapter13/movingRefinedMesh" i get the above error. (Please see the attached files for the newly built class and test case). I am using OpenFOAM 2.3.1 but i also tested the same with version 2.2.x as per the book but still the same error appears. Can somebody help me in this.please let me know in you need more info. from my end to make it more clear. mail me if required at - rupesh@cms.unipune.ac.in Thanks a lot for help |
Rupesh
Unfortunately i am unable to attach the test case file here as it exceeds the allowable size of 194kb, Please email me if anyone wants the test case file. Also you can get the same on git repository. link: https://bitbucket.org/sourceflux/primer-examples
Thanks in advance. |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 09:07 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
