January 26, 2016, 11:22 |
Run time selection of near-wall cells
Rep Power: 12 |
is there a way to select all near wall cells (cells directly at the wall) in each time step with swak4Foam? I want to calculate a new field which depends among other things on the distinction if the cell is next to a wall or not. The problem is, that I use dynamic mesh refinement, so creating a cellSet beforehand and check for it is not working in this case. |
dynamic mesh, near wall cell, swak4foam |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
Run time Selection Mechanism - Some help required to understand | jaswi | OpenFOAM Programming & Development | 3 | October 29, 2015 14:42 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 03:34 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 01:32 |
