sintax rules to compile setFieldsDict
Old   January 21, 2016, 13:45
Default sintax rules to compile setFieldsDict
Gabriele
leske is on a distinguished road
I'm working with a fairly simple geometry (kind of cilinder).
I would set a boundary condition on the entrance face of the cylinder that allows me to have a double entrance: water and oil. For this purpose,i thought about using setFieldsDict .In the tutorial i found several examples of setFields but all with boxToCell that isn't right for my case. I would use cylinderToCell but I can't use the right syntax rules.
Here below there is the text of my setFieldsDict:
| \\ / O peration | Version: 2.4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object setFieldsDict;
defaultFieldValues
volScalarFieldValue alpha.water 1
regions
cylinderToCell (0.5 0.01 0) (0.422878 0.01 0) 0.005;
fieldValues
volScalarFieldValue alpha.water 0
Can anyone help me ?
Thank you
Leske
leske is offline   Reply With Quote
Old   January 21, 2016, 16:06
cutter is on a distinguished road
You seem to be missing some braces and keywords. See post #2 of http://www.cfd-online.com/Forums/ope...ernatives.html
Cutter
cutter is offline   Reply With Quote
Old   January 21, 2016, 16:58
Gabriele
Hi cutter,
thanks for your reply that it was a big help!
leske
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
How to compile OpenFOAM-1.7.x on CrunchBang linux 10 gwierink OpenFOAM Installation 0 April 5, 2011 05:38
PV3FoamReader compile error.... PEM_GUY OpenFOAM Installation 6 April 5, 2010 18:22
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 14:24
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 22:51
