Simulation of a membrane distillation process (phase change and diffusion process)
Old   November 3, 2015, 22:13
Default Simulation of a membrane distillation process (phase change and diffusion process)
Federica
fkika is on a distinguished road
Hi Foamers.
I have to simulate the process of membrane distillation in which the membrane is hydrophobic and only vapour can pass through it. So, close to the membrane, the water evaporates and then the vapour go through it and condense in the permeate side.
I start with the declaration of the regions (water side, membrane, vapour side) using chtmultiregionFOAM. Now I want to add the phase change in the fluid solver. Do you think it is the right way?
Or I can use interPhaseChangeFOAM, specify the membrane with specific boundary conditions and add the heat equation.
Which of the two possibility will be successful? Any advice?
thank you.
fkika is offline   Reply With Quote
Old   February 21, 2018, 08:38
Sabrine BenSlama
Sabby is on a distinguished road
Did you get your job done ? I'm dealing with the same matter as you and i'm new with openFoam. Any suggestions that could help me ? Thank you
Sabby is offline   Reply With Quote
Problem with Temperature and volume fraction diffusion in Lee phase Change Model rapierrz OpenFOAM Programming & Development 3 June 6, 2020 07:49
velocity in diffusion process reyeszjj Main CFD Forum 1 March 21, 2010 04:24
Instability in phase change computations quicksilver Main CFD Forum 5 June 6, 2009 11:25
