BC Natural Convection Boundary Layer
Old   October 29, 2015, 08:35
Default BC Natural Convection Boundary Layer
Dominik
dodobenq is on a distinguished road
Hey Guys,
I'm trying to simulate the natural convection boundary layer along a vertical flat plate. The aim of this case is to investigate the heat-transfer from the wall (hot) to the surrounding air.
At first I tried to use the Cavity-Case with one heated wall. But then I got some interactions with the surrounding walls, e. g. the ambient temperature raises up. Therefore I'm trying to "open" the bottom and the top of the cavity and thereby in theory the hot air raise up and fresh air moves in. But now I have some problems in finding the right BC. I am thankful for all help and information!!!
Some facts:
- I'm using buoyantPimpleFoam
- I'm using kOmegaSST
- The Cavity has 4 types of patches: hot(wall), top(patch), bottom(patch), side(wall)
Now my BC:
k
hot
        type            fixedValue;
        value           uniform 1e-12;
top
        type            zeroGradient;
bottom
        type            fixedValue;
        value           uniform 0.00015;
side
        type            fixedValue;
omega
hot
        type            fixedValue;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        beta1           0.075;
top
        type            zeroGradient;
bottom
        type            fixedValue;
        value           uniform 0.0045;
side
        type            fixedValue;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        beta1           0.075;
p
ALL
        type            calculated;
        value           uniform 100000;
p_rgh
hot
        type         fixedFluxPressure;
top
        type         fixedValue;
bottom
side
T
hot
        type            fixedValue;
        value           uniform 333.15; // 60°C
top
        type            zeroGradient;
bottom
        type            fixedValue;
        value           uniform 289.15;
side
        type            fixedValue;
U
hot
        type            fixedValue;
        value           uniform (0 0 0);
top
        type            zeroGradient;
bottom
      type        outletInlet;
    phi        phi;
    outletValue    uniform (0 0 0);
side
        type            fixedValue;
mut
hot
        type            mutkWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
top
        type            calculated;
bottom
        type            calculated;
side
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
nut
hot
        type            nutLowReWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
top                // oben
        type            calculated;
bottom            // unten
        type            calculated;
side            // Seite
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
Kind Regards,
Dominik
dodobenq is offline   Reply With Quote
Old   November 3, 2015, 05:22
Dominik
Can anybody help me?
Old   November 3, 2015, 13:40
Joachim Herb
jherb is on a distinguished road
What is the problem with your settings? Does the simulation run?
For k I would suggest for both, top and bottom turbulentIntensityKineticEnergyInlet and for omega compressible::turbulentMixingLengthFrequencyInlet. Actually, I am not sure at all why there is a compressible version for omega but non for k.
For side use you have to decide if you want to use some wall function approach.
Could you get some outflow at the bottom?
Is a fixed temperature boundary condition at hot correct? The alternative could be the boundary condition compressible::turbulentHeatFluxTemperature
jherb is offline   Reply With Quote
Old   November 4, 2015, 04:07
Dominik
Thanks jherb for your answer!
The number of Iterations explodes after 2 seconds of simulated time :/
I'll try to put your suggestions in the case.
But now I've some further questions:
1) Is there also a "turbulentIntensityKineticEnergyOUTLET" for the patch "top" or
do I have to set it to "turbulentIntensityKineticEnergyInlet" as well?
2) "turbulentIntensityKineticEnergyInlet" - This functions says, that the inlet is turbulent, right? But I want to simulate a natural convection without any turbulence at the inlet
In the meantime I changed the patch "side" from "wall" to "patch".
THANKS!
Old   November 4, 2015, 04:25
Agustín Villa
agustinvo is on a distinguished road
Hello
I am dealing as well with this case. I am checking my BC's on each boundary you say.
What I don't understand at all is the fixed p and p_rgh. The solver only solves one of them, then it get the other.
What is the error you get?
agustinvo is offline   Reply With Quote
Old   November 4, 2015, 07:28
Dominik
Hey Augustin!
I've found another solution for this case on this german website: http://ww3.cad.de/foren/ubb/Forum527...9.shtml#000020
The main problem for this case is the p_rgh-file.
On the website they suggest:
U
    hot
        type            fixedValue;
    top                // oben
        type            pressureInletOutletVelocity;
    bottom            // unten
    side            // Seite
    front            // vorne
T
    hot
        type            fixedValue;
    top                // oben
        type         inletOutlet;
    inletValue    uniform 289.15;
    bottom            // unten
        type         inletOutlet;
    side            // Seite
        type         inletOutlet;
    front            // vorne
        type         inletOutlet;
p_rgh
    hot
    top                // oben
        type         inletOutlet;
    inletValue    uniform 100000;
    bottom            // unten
        type         totalPressure;
    U        U;
    gamma        1;
    p0        uniform    100000;
    phi        phi;
    psi        none;
    rho        rho;
    side            // Seite
        type         inletOutlet;
    front            // vorne
        type         inletOutlet;
I'm trying to run this case now and will report my solutions.
Old   November 4, 2015, 08:59
Agustín Villa
Hi Dominik
Which kind of fluid are you trying to simulate?
I am interested in incompressible ones, but buoyantBoussinesqPimpleFoam is not appropriate for my case. I have to use the incompressible options in buoyantPimpleFoam (the simulation takes a long time) or create a new incompressible solver with buoyancy forces, but this last one does not want to work!
Old   November 4, 2015, 09:12
Dominik
Hey!
I'm using compressible gas within a non-steady flow. I want to investigate the heat transfer on a vertical/horizontal flat plate with natural/forced convection.
Kind Regards
Old   November 4, 2015, 09:37
Joachim Herb
Here is the source code of turbulentIntensityKineticEnergyOUTLET:
https://github.com/OpenFOAM/OpenFOAM...hScalarField.H
You could use it for both inlet and outlet, as for the outlet case it automatically is switched to zeroGradient.
You might also set the turbulence at the open boundaries to an outletInlet with an inletvalue of 0 (or perhaps a very small number).
THANKS!
Old   November 6, 2015, 04:17
Agustín Villa
Hi Dominic! Did you obtain some results?
Are you comparing with any benchmark?
buoyantpimplefoam, convection heat flux, open cavity
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Radiation interface hinca CFX 15 January 26, 2014 18:11
natural convection boundary condition thomasyangfly FLOW-3D 3 September 11, 2012 11:14
Questions about Boundary Layer Thickness and Turbulence Models famerfamer STAR-CCM+ 3 July 12, 2012 10:47
