p_rgh B.C for compressibleInterFoam
Old   October 20, 2015, 13:18
Default p_rgh B.C for compressibleInterFoam
Rohith
RaghavendraRohith is on a distinguished road
Can somebody clarify why should the p_rgh (Dynamic pressure) must be set to 1e5. I am trying to simulate a wetting process using compressibleInterFoam. The simulation is very unstable when the following B.C. have been used
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1e5;
upperWall
         type            fixedFluxPressure;
          value		 uniform 1e5;
    leftWall
       value		 uniform 1e5;
    rightWall
      value		 uniform 1e5;
    lowerWall
          value		 uniform 1e5;
    frontAndBack
        type            empty;
I have change the p_rgh B.C on the walls to 0 Pa and pMin the same as 1e5. My geometry has Atmospheric Conditions. By using p and pMin 1e5, the material properties of the Fluids remain constant. Am i modelling some non- physicality by considering the p_rgh to 0. My fluid is static at the beginning of the simulation i.e, the corresponding B.C of U are uniform (0 0 0) for all Walls.
Thanks in Advance,
Best Regards,
Rohith
RaghavendraRohith is offline   Reply With Quote
Old   October 26, 2015, 09:37
Fabian Roesler
fabian_roesler is on a distinguished road
Hi Rohith
Hope you are fine. When changing the pressure boundary to 0 Pa with a minimum pressure of 1e5 Pa, the solver will correct the interior pressure to the allowed minimum of 1e5 Pa in every cell. Thus, all cells have a corrected pressure, not matching the real conditions in the domain. Your results are wrong.
Actually I am surprised, that the solver gives you values at all. With a 0 Pa absolute pressure, the ideal gas law should give you a division by zero.
Cheers
Fabian
fabian_roesler is offline   Reply With Quote
Old   October 26, 2015, 09:40
Rohith
Hi Fabian,
I am doing fine. Thank you for the reply. But my question was on p_rgh instead of p. I set p to 1e5 but p_rgh to 0 in some cases. Does it make some sense? was my question.
VG,
Rohith
Old   October 26, 2015, 09:49
Fabian Roesler
To clarify a little bit more: You're using a pressure of 1e5 Pa in every cell to calculate your thermophysical properties with. That's the reason why your properties are constant and the solver is more stable.
When choosing values for pMin/pMax, you have to decide where you want to bound your thermophysical properties. For example chose 1e4 Pa and 2e5 Pa for a simulation running at standard pressure 1e5 Pa with only slight pressure changes.
Cheers
Fabian
Old   October 26, 2015, 09:50
Fabian Roesler
You define p_rgh and p is type calulated.
p_rgh 0 should not work.
However, sometimes p_rgh field is calculated in the first time step from the p field.
Old   October 26, 2015, 09:55
Rohith
For a detailled Explaination let me show what i have as
|  \\    /   O peration     | Version:  2.1.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
boundaryField
    upperWall
        type            calculated;
        value           $internalField;
    leftWall
        type            calculated;
    rightWall
        type            calculated;
    lowerWall
        type            calculated;
    frontAndBack
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    object      p_rgh;
internalField   uniform 0;
upperWall
          value		 uniform 0;
    leftWall
       value		 uniform 0;
    rightWall
      value		 uniform 0;
    lowerWall
          value		 uniform 0;
    frontAndBack
        type            empty;
Old   October 26, 2015, 10:07
Fabian Roesler
No, this is not possible, as your pMin will correct the field everywhere. Thus, your thermophysical properties are wrong.
Old   October 26, 2015, 10:13
Rohith
Thank you!! This is what was expected. Have a nice day
Heat transfer over prediction in coupled b.c. meriam_1260 FLUENT 0 February 20, 2014 11:29
how to set such B.C. in Fluent? Sherri FLUENT 1 January 12, 2006 13:32
Urgent! Help on UDF to set B.C. of 3rd type Ray Hong FLUENT 0 December 28, 2005 20:35
How to set B.C. of the 2nd or 3rd type in UDS? Ray Hong FLUENT 0 December 28, 2005 07:03
Non-Reflecting B.C. in NSC2KE Zou Chu Main CFD Forum 2 May 27, 1999 22:26
