implementation of constant water levels as boundary conditions
Old   October 6, 2015, 12:19
Default implementation of constant water levels as boundary conditions
horn
horn is on a distinguished road
I want to create a 3D case of two communicating vessels with a water level difference, which are connected by a siphon. I have set this model up with snappy hexmesh (see attached figure). My interest lies in the flow speeds through the siphon as a result of the implemented water level difference.
Due to the flow the water level in the left vessel will decrease, while the level in the right vessel will increase. This is however something that I do not want because I am purely interested in the flow between those vessels given the current water level difference.
My question is: how can you set up your model (boundaries) in a way that water flows through the siphon due to the difference in energy level, while the water level is kept constant in both vessels?
I guess the solution has to do with adding the correct amount of water to the left vessel and substracting it from the right vessel based on the flow in the siphon.
Does anyone have an idea regarding this problem?
Geerten
horn is offline   Reply With Quote
Old   October 12, 2015, 17:19
Jerome Berryhill
Jerome Berryhill is on a distinguished road
Just from a physics POV, what you really want is the flow due to a constant pressure. The fact that that pressure is generated by a difference in water levels is irrelevant.
Jerome Berryhill is offline   Reply With Quote
Old   October 12, 2015, 18:45
Jerome Berryhill
Thinking about it further, what you want to know is flow as a function of pressure. But iwith OpenFOAM, it is probably easier to set the flow, and calculate the pressure. So, run a series of simulations at increasing flow, until you get one where the pressure difference corresponds to the level difference you are interested in.
boundary conditions, constant boundary, dependend boundary, open channel
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
