September 30, 2015, 12:13 |
topoSet tolerance
Anton Kidess
Rep Power: 30 |
I'd like to use topoSet together with createPatches to specify boundary conditions on a complex surface. I give topoSet an stl and use the triSurfaceMesh option to mark the faces I'd like to add to the new patches. So far so good, except that topoSet's tolerances are so tight that I don't end up with a smooth patch, but something akin to Swiss cheese. Is it possible to relax the tolerances that topoSet uses so that really all faces I'm interested in are picked up?
Cheers Anton
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 04:35 |
STL import is not working | zordiack | enGrid | 9 | July 1, 2014 15:49 |
2D isothermal cylinder not converging | UPengineer | OpenFOAM Running, Solving & CFD | 7 | March 13, 2014 06:17 |
fvSchemes, Fina residual tolerance not working | Attesz | OpenFOAM Running, Solving & CFD | 3 | March 20, 2012 04:26 |
stitchMesh for uncongruent patches (stitch tolerance) | beugold | OpenFOAM | 0 | June 18, 2009 08:38 |
