Pressure Probes for a cylinder (2D)
Old   September 28, 2015, 05:45
Default Pressure Probes for a cylinder (2D)
Erika
erikasj is on a distinguished road
Hi!
I am trying to place pressure probes on my cylinder to calculate the pressure on the surface during a transient 2D run. I have the locations of my nodes as well as face centers (as a written output from OF). I would ideally like to have the probes specified in controldict located in the face centers. However, when I try to run openfoam I get these errors.
FOAM Warning :
From function findElements::findElements(const fvMesh&)
in file probes/probes.C at line 111
Did not find location (-6.946264978e-05 -5.347075807e-05 0) in any cell.
The points (nodal) are offset from the surface. Since its a 2D case I have used a depth of 1 (but scaled down here)
(-6.840740679e-05 -5.485494298e-05 0.0004295719152)
To me the z offset of 0 would also indicate that the probe would be placed on the cylinder.
I would be very grateful for any help!
Thanks!!
erikasj is offline   Reply With Quote
Old   October 13, 2015, 13:49
Bazinga is on a distinguished road
I just tried the same and if the probe was exactly on the face of the cell at the boundary I got the same error. I moved the probe just slightly inside the cell and it worked.
Bazinga is offline   Reply With Quote
probes cylinder
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 11:34
Forces Acting on a Rotating Cylinder (Moving Mesh) dreamchaser CFX 5 April 25, 2015 07:01
InterPhaseChangeFoam ERROR shipman OpenFOAM Running, Solving & CFD 37 March 23, 2014 13:43
Translate the pressure field on a cylinder side to a plane rockzh CFX 7 November 23, 2011 01:50
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
