Modelling a flow around a square (with sharp edges)
Old   September 23, 2015, 07:27
Default Modelling a flow around a square (with sharp edges)
Andy_ilek is on a distinguished road
Hey,
I'm tring to model a 2D flow around a square. I used the following conditions:
- Solver: PisoFoam
- Turbulence Model: k-omega SST
- velocity uniform: 22m/s
- The square is 40m*40m (So i get really high Re-Number)
The input files are attached below. Does anybody already modelled a body with sharp edges and high Reynoldsnumber and has experience setting the boundary condition?
Is there something different than setting boundary conditions for an airfoil?
thanks already
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (22 0 0);
boundaryField
inlet
type freestream;
freestreamValue $internalField;
outlet
type freestream;
upanddown
type freestream;
body
type fixedValue;
value uniform (0 0 0);
frontandback
type empty;
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 85796;
boundaryField
inlet
type freestreamPressure;
outlet
upanddown
body
type zeroGradient;
frontandback
type empty;
FoamFile
version 2.0;
format ascii;
location "0";
object k;
internalField uniform 0.01;
boundaryField
inlet
type inletOutlet;
inletValue $internalField;
outlet
type inletOutlet;
upanddown
type inletOutlet;
body
type kqRWallFunction;
value uniform 0;
frontandback
type empty;
FoamFile
version 2.0;
format ascii;
object omega;
dimensions [0 0 -1 0 0 0 0];
internalField uniform 100;
boundaryField
inlet
type inletOutlet;
outlet
type inletOutlet;
upanddown
type inletOutlet;
body
type omegaWallFunction;
value uniform 0; // es bleibt allerdings durch die WallFunction nicht 0 !
frontandback
type empty;
FoamFile
version 2.0;
format ascii;
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0.14;
boundaryField
inlet
type freestream;
outlet
type freestream;
upanddown
type freestream;
body
type nutkWallFunction;
value uniform 0;
frontandback
type empty;
Andy_ilek is offline   Reply With Quote
Old   September 28, 2015, 03:44
Nima Samkhaniani
nimasam is on a distinguished road
it seems OK for me , just some small questions:
1- did you check Mach number? is it incompressible flow (Mach < 0.3)?
2- you use incompressible solver pisoFoam, is there any reason you assign p = 85796 ? you could put it zero
3- if you are looking for steady state solution, then simpleFoam can be considered too
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 06:16
modelling slug flow with pressure inlet Azman FLUENT 0 May 29, 2006 07:45
Slug flow in square channel PaulC FLUENT 0 December 5, 2005 03:03
Compressible Flow Modelling? yeo FLUENT 4 March 7, 2003 08:08
