Introducing changeDictionaryDict and topoSetDict files in chtMultiRegionFoam |
September 19, 2015, 13:44 |
Franco
Rep Power: 11 |
here is a new OpenFoam user. I'm trying to solve a simple heat transfer exercise, i want to analyse the heat conduction through a 2D geometry. In this 2D geometry, there are several sub-regions and each sub-region has its own thermo-physical properties (see attached file). In order to do that, I'm using chtMultiRegionSimpleFoam. Here's what I've done: -I made the geometry and the mesh using Salome, -I used the command idesUnvToFoam to create the polymesh directory into the constant folder, - I used the command splitMeshRegions -cellZones -overwrite to to create the several sub-regions into the folders 0, constant and system, I created the regionProperties files and I introduced the thermpphysicalproperties file. Now, I need to modify the files into the system directory. However, I'm having troubles, since I don't know how to create the several changedirectoryDict files (in the sub-regions) and the topoSetDict file (in the system folder). So my questions are
Thank you very much!!! Franco Last edited by fracasce; October 5, 2015 at 10:42. Reason: I forgot to upload the attached file |
October 3, 2015, 11:00 |
nasir musa yakubu
Rep Power: 12 |
I have the same problem, right now, i have a complex geometry with many 3D parts however ( a solar volumetric receiver), i have used snappyhexmesh to mesh my still files but i don't understand how to utilize changedictionarydict, if there is a single code to do it, that would be helpful.
Also if anyone can shed more light on how to set the changedictionarydict, that will be also helpful. thanks |
October 3, 2015, 11:17 |
Joćo Ferreira
Rep Power: 11 |
the topoSet is used to create zones in the mesh, which can after be split into regions using the splitMeshRegions command. Has others uses but the objective here are the regions I think. Anyway if you can create your regions converting the UNV file and using splitMeshRegions, you don't need to use topoSet, at least from my experience. I used the same procedure and the only thing I had to do was to rename the regions (they were created as domain*) and proceed to run the case. About changeDictionaryDict, you can use the wildcard ".*" to give the same initial condition to every boundary. For example, if you have several outlets and all of them start with "outlet_" if you define in the changeDictionaryDict file as "outlet_.*" everyone of them are going to be defined in the same way. What I had to do to make it work was to insert, in the 0 directory files, the name (only the name) of every boundary of the region. After doing this the wildcard and my changeDictionaryDict file were working very well. |
October 6, 2015, 15:24 |
ChangeDictionaryDict introduction
#4 | |
Franco
Rep Power: 11 |
Hi jmdf,
thank you very much for your reply, it's been very helpful. Howerver, I don't understand how to introduce the changeDictionaryDict file. Quote:
Thanks by now |
October 6, 2015, 15:37 |
Joćo Ferreira
Rep Power: 11 |
you can copy the changeDictionaryDict file from any tutorial and then adjust it to your case, i'm not aware of any other way to do it. Here comes handy the use of the wildcard ".*" to define several boundary conditions at the same time. So basically i would do it like this: 1. Copy the dict file to every region on the system folder and adjust it to the case; 2. Run changeDictionary -region <region name> for every region you have; Hope this helps! |
October 6, 2015, 19:48 |
#6 | |
nasir musa yakubu
Rep Power: 12 |
Thanks for your reply, i have done what you said, created a folder and copied the changedictionarydict, decomposepardict fvschemse and fvsolutions. for every single region. however i have a multiple geometries about 21 including inlet and outlet, with only 3 different solid regions(materials) and a single fluid. . how do i go about modifying the boundary? i am trying to say, i have no idea how it is structured eg, i am trying to modify the changedictionarydict, bellow. i can easily guess what the individual lines mean but not the overall file. i am going to highlight the bits i don't understand the meaning in red. i would appreciate further clarifications. Code:
dictionaryReplacement { boundary [COLOR="rgb(139, 0, 0)"] { minY { type patch; } minZ { type patch; } maxZ { type patch;[/COLOR] } } T { internalField uniform 300; boundaryField { ".*" { type zeroGradient; value uniform 300; } "heater_to_.*" { type compressible::turbulentTemperatureCoupledBaffleMixed; Tnbr T; kappa solidThermo; kappaName none; value uniform 300; } minY { type fixedValue; value uniform 500; } } } } Last edited by esujby; October 30, 2015 at 21:45. |
October 7, 2015, 03:47 |
#7 | ||
Joćo Ferreira
Rep Power: 11 |
I will try to explain what I understand from this file. Quote:
Converting a mesh from Salome, usually boundaries are defined as walls, so for the inlets/outlets you can use the changeDictionary tool or change it directly on the boundary file on the constant folder. Quote:
Remember that the names on this file are for the tutorial and so you have to change them according to your case. Hope this helps |
October 13, 2015, 07:51 |
nasir musa yakubu
Rep Power: 12 |
Thanks very much for your reply, it has helped me allot in further defining my case, however, i am wondering, since i have 21 changedict folders in the system folders for all my geometries, must i specify the following in each of the changedictionarydict in every single folder representing each geometry: Code:
dictionaryReplacement { boundary { inlet { type patch; } outlet { type patch; } } T { internalField uniform 300; boundaryField { ".*" { type zeroGradient; value uniform 300; } Also, with regards to my case, i don't have a solid heater heating up the geometries per say. what i want to use is a non uniform heat flux boundary condition (result from monte carlo solar ray tracing), in table, grid, and or array format (100x 100 elements) representing the concentrated heat flux on a circle with 3cm radius propagating along one direction to heat up the wall and fluid regions and between the walls and fluid regions, there would be heat transfer interms of radiation, convection and conduction. this will be carried out in order to calculate the exit gas temperature. so i am wondering how to go about modifying the boundary section bellow. thanks Code:
"heater_to_.*" { type compressible::turbulentTemperatureCoupledBaffleMix ed; Tnbr T; kappa solidThermo; kappaName none; value uniform 300; } minY { type fixedValue; value uniform 500; } } } } Kind regards Last edited by esujby; October 30, 2015 at 21:46. |
October 28, 2015, 04:25 |
#9 |
Joćo Ferreira
Rep Power: 11 |
regarding the first part, each region has its own boundaries so on the regions you need to change the boundary type you have to use the boundary type entries. For the initial conditions you need a changeDict file on every system folder with the conditions you want to used for each boundary. The second part, to consider energy exchange between the regions the compressible::turbulentTemperatureCoupledBaffleMix ed is what you need to use. The concentrated heat flux on a circle, if you create that zone/faceSet with topoSet and define on it the heat flux you want it might work although I never did something like that. PS: sorry for my late response |
changedictionary, chtmultiregionfoam, salome 7, toposetdict |
Error in thermophysical properties (chtMultiRegionFoam) | mukut | OpenFOAM Pre-Processing | 28 | November 23, 2021 06:34 |
topoSetDict | samiam1000 | OpenFOAM | 5 | July 23, 2019 11:45 |
Turbulences from Toposetdict??? | Ingenieur5 | OpenFOAM Running, Solving & CFD | 2 | May 28, 2018 23:07 |
topoSetDict by Mesh from another Software | Parisa_Khiabani | OpenFOAM Pre-Processing | 3 | December 12, 2014 06:29 |
chtMultiRegionFoam Set-up | michael157 | OpenFOAM Pre-Processing | 2 | July 4, 2014 17:12 |
