Using block faces to define faceSets in topoSet?
Old   September 15, 2015, 12:59
Default Using block faces to define faceSets in topoSet?
Sofy
sweisenb is on a distinguished road
I have used blockMesh to create a mesh.
I would like to use topoSet to sample flow rate through several internal faces of my mesh. I am wondering how best to do this as the faces are curved and are not oriented in such a way as to be easily captured with the boxToFace tool.
I thought to use the patchToFace tool, but the faces are internal and therefore cannot be specified as patches in my blockMeshDict file.
The faces are, however, faces of blocks defined in my blockMeshDict script. Therefore, I wonder if there is a way to define the faceSets for topoSet based on the location of the face vertices, which I know.
I have many such faces to sample and am therefore looking for a tool that can be looped in a script.
Also, can anyone give me an example of how the boundaryToFace or labelToFace tools would be implemented? What are "boundaries" or "labels" in this case and how do they work?
Thank you very much for any advice!
sweisenb is offline   Reply With Quote
blockmesh, faceset, toposet
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 11:19
