Trying to understand: What is the "boxToCell"?
Old   September 8, 2015, 01:15
Default Trying to understand: What is the "boxToCell"?
jhYang
jhYang is on a distinguished road
I don't know how do I set-up the boxToCell.
In user guide it says just min and max.
I want to know that how calculate the min and max to the boxToCell??
jhYang is offline   Reply With Quote
Old   September 8, 2015, 11:20
Sravan Kumar
coolcrasher is on a distinguished road
boxToCell -- is to set field values to part of your domain, it overwrites the default values set for the fields in zero folder ( example - specified by internalField uniform 0; )
For this you have to specify the start point and end point of diagonal of your box ( which should be inside your domain ).
Example:
boxToCell
26      {
27          box (0 0 -1) (0.1461 0.292 1);
28          fieldValues
29          (
30              volScalarFieldValue alpha.water 1
31          );
32      }
start point here is ( 0 0 -1 ) and end point is ( 0.1461 0.292 1 ).
Field values represent the the list of field values you want to set inside this box which overwrites the field values set in zero folder in this box region.
You can run this boxToCell by adding setFieldsDict file in your systems folder and give the parameters you want to set. You can run the file from terminal after blockMesh, by saying setFields.
You can get the sample setFieldsDict file in DamBreak tutorial of openFoam.
Hopefully this clarifies your doubt
coolcrasher is offline   Reply With Quote
Old   September 8, 2015, 21:36
Default Thanks very much:)
jhYang
Thank you very much for your help:^)
but I still don't know how I set-up the coordination of the boxToCell.
Old   September 9, 2015, 03:38
Sravan Kumar
I do not understand your question, can you elaborate ??
Old   September 9, 2015, 03:55
Default :)
jhYang
Um.. well boxToCell and blockMesh are not related?
And this case(red thing is fluid), yellow point is the boxToCell's coordination??
I really know that how to make coordinations for boxToCell.
Old   September 9, 2015, 04:50
Sravan Kumar
Hi
you can get the coordinates of your domain from paraview.
After you do blockMeshon your case, open the mesh in paraview using paraFoam.
You have a tool named probe location, which will show you the point in your geometry and will give you the coordinates. You can move the point using your mouse ( which is difficult ) or you can move it by changing the value in the coordinates manually.
It would be quite a work to get the exact values but need patience, it would work.
I guess this clarifies your question
Best regards
How do I make boxToCell jhYang OpenFOAM Pre-Processing 1 September 17, 2015 05:28
boxToCell alternatives silo OpenFOAM Pre-Processing 2 February 12, 2015 05:58
[Other] boxToCell versus rotatedBoxToCell engineer_the OpenFOAM Meshing & Mesh Conversion 2 August 6, 2014 15:07
.setSet problems Grimoli OpenFOAM 9 July 31, 2013 14:24
Bug? refineMesh boxToCell negative coordinates lindstroem OpenFOAM 2 June 20, 2011 09:06
