July 27, 2015, 06:23 |
Linear Density Gradient
Nicholas Kong
Dear all,
I have been given the task to simulate a flow with a linear density gradient. The control volume has an inlet and outlet surrounded by four walls. The inlet should be able to produce a stratified flow with low density at the top and high density at the bottom. I am unable to find any information regarding this topic. What kind of approach should I use to solve this problem? Nick Last edited by nicholas.kong; July 27, 2015 at 11:14. |
density, gradient, linear |
Contours of density gradient in fluent 5? | Ricky Wong | FLUENT | 3 | May 19, 2015 02:39 |
A turbulent test case for rhoCentralFoam | immortality | OpenFOAM Running, Solving & CFD | 13 | April 20, 2014 07:32 |
error on turbulence scheme | immortality | OpenFOAM Pre-Processing | 11 | August 21, 2013 09:45 |
Specifying vertical density gradient in FLUENT | ajagan | FLUENT | 0 | August 18, 2011 23:16 |
Unit of Density Gradient | Eric | Main CFD Forum | 4 | August 20, 2007 10:33 |
