July 16, 2015, 02:56 |
axial fan bc
daniel
Rep Power: 11 |
Hi
I am looking to setup a simulation of an axial fan in a room, I want to set up the fan as an internal fan so I have a model with a cylinder the size of the fan inside a room. I am new to open foam can some one point me in the right direction , at this point as far as I understand it I can use rhopimplefoam for the solver? And interms of boundary condition for the fan I would have to use a cyclic boundary to link the inlet and outlet of the fan ? Or are there alternative methods of setting up a fan bc ? Also I found this (fanPressureFvPatchScalarField.H) but there is a lack of documentation would this work and how would I implement it ? |
July 17, 2015, 10:40 |
TJunctionFan
daniel
Rep Power: 11 |
Ok so I have done some digging around on the forum and found the TjunctionFan tutorial that uses cyclic bc to define a fan.
I found some parts of the config file that I dont understand, in the system folder there is a file topoSetDic. if some one has time could they clarify how the bc is applied to the two faces and what does the baffleFaces define ? |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
Axial fan or blower cooling a hot object with recirculation | mariconeagles96 | CFX | 4 | April 18, 2012 08:41 |
urgent pressure condition for axial flow fan | VIPUL | FLUENT | 0 | October 24, 2008 02:01 |
Axial Fan | Russ | FLUENT | 8 | July 7, 2006 13:59 |
axial flow in counter rotating ducted fan | Vishu | FLUENT | 4 | January 13, 2004 17:52 |
