Temperature in chtMultiRegionSimpleFoam diverges |
July 10, 2015, 09:40 |
Rep Power: 15 |
I have a chtMultiRegionSimpleFoam case with these boundary conditions for T:
0/inner/T (the "inner" region is a channel, heated by "outer") Code:
dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { ".*" { type zeroGradient; } port_minX { type fixedValue; value $internalField; } inner_top_to_outer_bottom { type compressible::turbulentTemperatureCoupledBaffleMixed; value $internalField; neighbourFieldName T; kappa fluidThermo; kappaName none; } inner_bottom_to_outer_top { type compressible::turbulentTemperatureCoupledBaffleMixed; value $internalField; neighbourFieldName T; kappa fluidThermo; kappaName none; } } Code:
dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { ".*" { type zeroGradient; } cyclic_half0 { type cyclic; neighbourPatch cyclic_half1; } cyclic_half1 { type cyclic; neighbourPatch cyclic_half0; } port_maxX { type fixedValue; value $internalField; } outer_bottom_to_inner_top { type compressible::turbulentTemperatureCoupledBaffleMixed; value $internalField; neighbourFieldName T; kappa fluidThermo; kappaName none; } outer_top_to_inner_bottom { type compressible::turbulentTemperatureCoupledBaffleMixed; value $internalField; neighbourFieldName T; kappa fluidThermo; kappaName none; } } This is my fvSolution for both regions, taken from the tutorials: Code:
solvers { rho { solver PCG preconditioner DIC; tolerance 1e-7; relTol 0; } p_rgh { solver GAMG; tolerance 1e-7; relTol 0.01; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } "(U|h|k|epsilon)" { solver PBiCG; preconditioner DILU; tolerance 1e-7; relTol 1e-3; } } SIMPLE { momentumPredictor on; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; rhoMax rhoMax [ 1 -3 0 0 0 ] 998.21; rhoMin rhoMin [ 1 -3 0 0 0 ] 998.21; } relaxationFactors { fields { rho 1; p_rgh 0.7; } equations { U 0.3; h 0.7; nuTilda 0.7; k 0.7; epsilon 0.7; omega 0.7; "ILambda.*" 0.7; } } Yet, at some point, the solver crashes with these messages: Code:
Time = 1.189 Solving for fluid region inner DILUPBiCG: Solving for Ux, Initial residual = 0.008097846421495124, Final residual = 1.691752979096075e-06, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.01202702721211336, Final residual = 4.67365575791039e-06, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.006397124599835598, Final residual = 4.510605145494105e-06, No Iterations 2 DILUPBiCG: Solving for h, Initial residual = 0.007301157391312279, Final residual = 4.435109962802407e-06, No Iterations 4 Min/max T:-12.32577060925731 535.8323171660503 GAMG: Solving for p_rgh, Initial residual = 0.01418968895726693, Final residual = 0.0001296874831464765, No Iterations 17 time step continuity errors : sum local = 0.08093283579305911, global = -0.006680036867943988, cumulative = 17.0641256372114 Min/max rho:998.21 998.21 Solving for fluid region outer DILUPBiCG: Solving for Ux, Initial residual = 0.008011336199895795, Final residual = 3.491116546908557e-06, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.009841596835628913, Final residual = 2.399052759444415e-07, No Iterations 3 DILUPBiCG: Solving for Uz, Initial residual = 0.005885879944786529, Final residual = 7.480876455413755e-08, No Iterations 3 DILUPBiCG: Solving for h, Initial residual = 0.0099630601584084, Final residual = 7.906802165940321e-06, No Iterations 4 Min/max T:81.79784497198106 631.2266884469128 GAMG: Solving for p_rgh, Initial residual = 0.01235827895320395, Final residual = 0.0001215156797075635, No Iterations 18 time step continuity errors : sum local = 0.1279884342953329, global = 0.0148764476852957, cumulative = 17.0790020848967 Min/max rho:998.21 998.21 ExecutionTime = 246.96 s ClockTime = 248 s Time = 1.19 Solving for fluid region inner DILUPBiCG: Solving for Ux, Initial residual = 0.008105661650416348, Final residual = 1.693579077882211e-06, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.01204669200529919, Final residual = 4.699218819825913e-06, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.006395075395368484, Final residual = 4.432119799919217e-06, No Iterations 2 DILUPBiCG: Solving for h, Initial residual = 0.007377178229246799, Final residual = 4.29591370137443e-06, No Iterations 4 --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const in file /local/brf/OpenFOAM/OpenFOAM-2.2.0/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy>::T(double, double, double, double (Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double) const) const at ??:? #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? #4 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? #5 at ??:? #6 __libc_start_main in "/lib64/libc.so.6" #7 at /home/abuild/rpmbuild/BUILD/glibc-2.17/csu/../sysdeps/x86_64/start.S:126 Aborted Code:
pointSync false; // Patches to create. patches ( { // Name of new patch name inner_top_to_outer_bottom; // Dictionary to construct new patch from patchInfo { sampleRegion outer; samplePatch outer_bottom_to_inner_top; type mappedWall; sampleMode nearestPatchFaceAMI; offsetMode uniform; offset (0 0 0); } // How to construct: either from 'patches' or 'set' constructFrom set; // If constructFrom = set : name of faceSet set wallTopFaces; } { // Name of new patch name inner_bottom_to_outer_top; // Dictionary to construct new patch from patchInfo { sampleRegion outer; samplePatch outer_top_to_inner_bottom; type mappedWall; sampleMode nearestPatchFaceAMI; offsetMode uniform; offset (0 0 0); } // How to construct: either from 'patches' or 'set' constructFrom set; // If constructFrom = set : name of faceSet set wallBottomFaces; } ); Best regards |
July 10, 2015, 14:25 |
Alex
Rep Power: 21 |
Only two fluid regions are defined in your case? Maybe I cannot help you too much becuase I don't know if the patch creation process is correct or not. However, as a quick advice, try decreasing the relaxation factor for h for the region inner, which the one that crashes. Otherwise, try reducing both relaxation factors and run the solver again.
Hope it helps a bit. Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
July 13, 2015, 03:58 |
Rep Power: 15 |
I reduced the relaxation factor for equations->h to 0.1 in both regions, now it crashes in region "outer" with the same message, and temperatures in both regions are far off (inner min/max T:53.20372142006549 1117.386976095008). There's still something wrong, and I think it's related to the boundary conditions.
July 13, 2015, 06:43 |
Rep Power: 15 |
it turned out that this was related to an error in my BCs for U. One of them was not a no-slip BC, but zeroGradient. I should have posted my whole case instead of just those parts which I thought contained the error.
July 13, 2015, 10:57 |
Alex
Rep Power: 21 |
I think that zeroGradient and no slip BC do exactly tha same... The problem you experience may be related to the coupling boundaries, have you tried to check which cells provoke the crash with paraview?
July 14, 2015, 07:27 |
Rep Power: 15 |
No, no-slip and zeroGradient don't do the same thing. Consider a uniform flow that would go through a wall, like this:
October 5, 2016, 01:35 |
Rep Power: 13 |
November 18, 2016, 10:13 |
Laurent DASTUGUE
Rep Power: 12 |
i have the same problem but with the solver : chtMultiRegionFoam. Any explanations on this topic ? Because in a transient case, i can't play with the relaxation factor to not break the continuity.
Laurent D. |
Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 11:43 |
fluid flow but temperature raises from nowhere? | mxcfd | STAR-CCM+ | 5 | September 16, 2014 05:46 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 17:12 |
where is the calculation of the temperature field | Tobi | OpenFOAM | 1 | July 30, 2012 10:40 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
