July 2, 2015, 05:32 |
Master and slave patch in create baffles.
Divyaprakash
Rep Power: 12 |
What are patch pairs in createBaffles. I need to create a patch which should be used only by the forceCoeffcients function object to calculate CD and CL. Other than that the patch should have no physical significance. Is it possible to create such a patch using create baffles?
baffles, coefficient drag, master, patch, slave |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
big difference between clockTime and executionTime | LM4112 | OpenFOAM Running, Solving & CFD | 21 | February 15, 2019 04:05 |
Integer stack memory insufficient | mactech001 | CFX | 1 | May 15, 2014 07:22 |
Conjugate heat transfer | sunilpatil | CFX | 1 | January 25, 2013 12:42 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
