May 27, 2015, 06:17 |
how create a liquid film on specific face
I try to use OpenFOAM to simulate the dynamic of a film on a solid surface. I need to patch a film on the surface (with a specific thickness). I know how to use the setFieldsDict to initialize the alpha value (liquid) in box (boxToCell) or a sphere (SphereToCell). Unfortunalty the surface that I need to use is not plane (it is a curved shape), so I can't use boxToCell. Anybody know how to set the alpha value near a curved surface (is a parabolic shape)? The optimum is to create a film, attached to this curved surface, with a desired thickness t. Thanks for your help Fabio |
May 27, 2015, 08:12 |
Cedric DUPRAT
Rep Power: 17 |
Fabio,
You could have a look on the solver reactingParcelFilmFoam and its tutorials. I don't know which solver you are using but with this one you can solve a wall film, coupled or not with lagrangian. In the initialization, you can define a patch dependant film defined by its thickness and its velocity (in the tangential direction only). I hope this will be helpful, best regards, Cedric |
May 28, 2015, 11:43 |
surfaceToCell
Thanks a lot Cetric,
I would like to use my solver, but I will take a look on reactingParcelFilmFoam, and I'll try it. anyway, someone know how to set an alpha value near a face that it is not planar. I know that exists "surfaceToCell", but I did't understand how to use that. anybody know how to use surfaceToCell? Thanks Fabio |
setfieldsdict curved |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 21 | August 19, 2021 15:18 |
Meshing a Sphere | Ajay | FLUENT | 10 | September 3, 2016 15:18 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
Create an internal face | aylalisa | OpenFOAM Pre-Processing | 1 | June 19, 2013 13:02 |
