Setting time-dependant velocity fields using FSF
Old   May 6, 2015, 02:13
Default Setting time-dependant velocity fields using FSF
Shayan
Shayansh is on a distinguished road
Hi everyone,
I am facing a case where I would like to change velocity field in a special position throughout solving time. I use funkySetFields as follow:
funkySetFields -field U -expression "U+vector (1,0,0)" -time ':2' -keepPatches -condition " pos().y > 0.48"
However, velocity fields despite being defined correctly in the beginning, gets modified based on equations in later time points.
Therefore, I would like to ask how one can modify a field in a time-dependant manner?
Thanks and best,
Shayan
Shayansh is offline   Reply With Quote
Old   May 12, 2015, 13:40
Nima Samkhaniani
nimasam is on a distinguished road
Dear shayan
if i understand your question properly, if you want to manipulated internalField you can use manipulatedField, but if you want to manipulated boundary condition, you should use groovyBC
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
funkysetfield
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
a reconstructPar issue immortality OpenFOAM Post-Processing 8 June 16, 2013 12:25
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
