Boundary Conditions
Old   April 30, 2015, 13:39
Default Transonic, Compressible, full flight scale Boundary Conditions?
Jimmy
MtnRunBeachBum is on a distinguished road
OK, I know I've been reaching out a lot, but everyone has been very helpful, and I'm learning a lot quickly. I think I'm finally stuck on settign up boudnary conditions.
The case is rhoCentralFoam, ~0.82 Mach, in the neighborhood of 30000'. See below for blockMeshDict, U, p, and T files:
blockMeshDict
convertToMeters 39.3700787; //0.0254; //(meters to inches)
vertices
    (-2.54 -15.24 -2.54)    //    (-100 -600 -100)        // full grid
    (30.48 -15.24 -2.54)    //    (1200 -600 -100)
    (30.48 15.24 -2.54)        //    (1200 600 -100)
    (-2.54 15.24 -2.54)        //    (-100 600 -100)
    (-2.54 -15.24 10.16)    //    (-100 -600 400)
    (30.48 -15.24 10.16)    //    (1200 -600 400)
    (30.48 15.24 10.16)        //    (1200 600 400)
    (-2.54 15.24 10.16)        //    (-100 600 400)
    (-2.54 0 -2.54)            //    (-100 -600 -100)        // half grid
    (30.48 0 -2.54)            //    (1200 -600 -100)
    (-2.54 0 10.16)            //    (-100 -600 400)
    (30.48 0 10.16)            //    (1200 -600 400)
blocks
//    hex (0 1 2 3 4 5 6 7) (100 100 100) simpleGrading (1 1 1)
    hex (0 3 7 4 1 2 6 5) (50 25 25) simpleGrading (1 1 1) // sets the block in order from X_min -> X_max
edges
boundary
    inlet
        type patch;
        faces
            (0 4 7 3)
    outlet
        type patch;
        faces
            (1 2 6 5)
    bottom
        type symmetryPlane;
        faces
            (0 1 5 4)
    top
        type patch;
        faces
            (2 3 7 6)
    front
        type patch;
        faces
            (0 3 2 1)
    back
        type patch;
        faces
            (4 5 6 7)
mergePatchPairs
p-file
dimensions      [1 -1 -2 0 0 0 0];        //compressible
//dimensions        [0 2 -2 0 0 0 0];    //incompressible
internalField   uniform 32932;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 32932;
    outlet
        type            zeroGradient;
    bottom
        type            symmetryPlane;
        //type            zeroGradient;        //fixedValue;
        //value           uniform 32932;
    top
        //type            symmetryPlane;
    front
    back
    fuselage
        type            zeroGradient;
    wings
        type            zeroGradient;
    vertTail
        type            zeroGradient;
    horizStab
        type            zeroGradient;
    engines
        type            zeroGradient;
    pylon
        type            zeroGradient;
    pylonExtension
        type            zeroGradient;
    pod
        type            zeroGradient;
U-file
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (251 0 0);
boundaryField
    inlet
        type            fixedValue;
        value            uniform (251 0 0);
    outlet
        type            zeroGradient;        //freestream;            //inletOutlet;
        //inletValue        uniform (251 0 0);    //
        //freestreamValue    uniform (251 0 0);
    bottom
        type            symmetryPlane;        //fixedValue;
        //value           uniform ( 0 0 0 );    //(0 0 0);
    top
        type            zeroGradient;
        //type            symmetryPlane;        //fixedValue;
    front
        type            zeroGradient;
        value           uniform ( 0 0 0 );    //(251 0 0)
    back
        type            zeroGradient;
    fuselage
        type            slip;
    wings
        type            slip;
    vertTail
        type            slip;
    horizStab
        type            slip;
    engines
        type            slip;
    pylon
        type            slip;
    pylonExtension
        type            slip;
    pod
        type            slip;
T-file
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 233;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 233;
    outlet
        type            zeroGradient;        //inletOutlet;
        value           uniform 233;
        //inletValue        uniform 233;
    bottom
        //value           uniform 233;
    top
        type            fixedValue;            //symmetryPlane;        //fixedValue;
        value           uniform 233;
    front
        value           uniform 233;
    back
        value           uniform 233;
    fuselage
        type            zeroGradient;
        value           uniform 233;
    wings
        type            zeroGradient;
        value           uniform 233;
    vertTail
        type            zeroGradient;
        value           uniform 233;
    horizStab
        type            zeroGradient;
        value           uniform 233;
    engines
        type            zeroGradient;
        value           uniform 233;
    pylon
        type            zeroGradient;
        value           uniform 233;
    pylonExtension
        type            zeroGradient;
        value           uniform 233;
    pod
        type            zeroGradient;
        value           uniform 233;
Based on the errors I get (very similar to this threat), I think most of the problem is in my boundary condition setup; however I am at wit's end...I am having trouble accounting for what looks to me to be differences in how the "patches" and so on are used for different type of solvers.
Any help or guidance would be appreciated, I've been pulling my hair out since last week, and really need it to run roday
Thanks!
MtnRunBeachBum is offline   Reply With Quote
Old   April 30, 2015, 17:33
Jimmy
...And because I failed to include the actual error message in the above (original) post:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  which: no linux-gate.so.1 in (/home/cfd/OpenFOAM/ThirdParty-2.3.1/platforms/linuxGcc/gperftools-svn/bin:/home/cfd/OpenFOAM/ThirdParty-2.3.1/platforms/linuxGcc/ParaView-4.1.0/bin:/home/cfd/OpenFOAM/cfd-2.3.1/platforms/linuxGccDPOpt/bin:/home/cfd/OpenFOAM/site/2.3.1/platforms/linuxGccDPOpt/bin:/home/cfd/OpenFOAM/OpenFOAM-2.3.1/platforms/linuxGccDPOpt/bin:/home/cfd/OpenFOAM/OpenFOAM-2.3.1/bin:/home/cfd/OpenFOAM/OpenFOAM-2.3.1/wmake:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl)
__kernel_sigreturn
#3  Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
#4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
 at ??:?
#6  __libc_start_main in "/usr/lib/libc.so.6"
 at ??:?
[cfd@cfd G3_pod_rhoCentralFoam_b]$
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 10:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
