Error: Floating point exception (core dumped)
Old   April 27, 2015, 04:23
Default Error: Floating point exception (core dumped)
JISHNU H
jishnuhari25 is on a distinguished road
p { margin-bottom: 0.08in; }a:link { } hi all,
While I am running the case for saturated flow boiling problem whose solver is developed using twoPhaseEulerFoam as the base solver, I am encountering with the following error.
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib64/libc.so.6"
#3 in "/lib64/libm.so.6"
#4 exp in "/lib64/libm.so.6"
#5 Foam::exp(Foam::dimensioned<double> const&) at ??:?
at ~/OpenFOAM/p2tf13007-2.2.2/applications/solvers/satBoilingFoam/Tempboiling.H:32 (discriminator 1)
#7 __libc_start_main in "/lib64/libc.so.6"
at ??:?
From debugging, it shows that error is in line TempBoiling.H:32. Corresponding line is
dimensionedScalar C1 = exp(-((Tsat-(tt*T2[faceCelli]))/delTref));
tt is provided to make the equation dimensionally correct.
Please check the case
thanks in advance
jishnuhari25 is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 07:51
ERROR : Floating point exception (core dumped) sam.ho OpenFOAM Running, Solving & CFD 4 December 3, 2013 06:25
pimpleDyMFoam constantly giving floating point exception and solution divergence fedvasu OpenFOAM Running, Solving & CFD 0 November 28, 2013 01:53
Finished simulation doesn't start: floating point exception [Divide by zero] MaxCFD STAR-CCM+ 3 June 26, 2011 11:31
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
