Bounday conditions for a natural convection boundary layer
Old   March 26, 2015, 10:30
Default Bounday conditions for a natural convection boundary layer
Agustín Villa
agustinvo is on a distinguished road
Hello!
I am setting up a natural convection boundary layer, where I impose a heat source (heat flux or fixed temperature) at a wall, but I don't know if the set up I am planning is good enough.
In the figure you can see my initial set up, and I will use buoyantBoussinesqPimpleFoam. The BC's I am imposing are:
  • Velocity
    • Wall = [0 0 0]
    • Inlet & outlet = zeroGradient
    • Free Stream = zeroGradient
  • Temperature
    • Wall = fixedTemperature_1 or turbulentHeatFluxTemperature
    • Inlet = fixedTemperature_2 (fixedTemperature_1>fixedTemperature_2)
  • k,epsilon, nut: low Re correction at the wall, zeroGradient in the rest of boundaries
  • p_rgh: equal to 0 at inlet, zeroGradient in the rest of boundaries
I am wondering if I should move to fixedValues in the Free Stream boundary (T_inf and U=[0 0 0]), but I don't like this idea since it will affect my boundary layer profiles, and setting very far from the wall this boundary can be done at this moment, but not in the future (LES simulations are planned).
If you think that I could improve my simulation by modifying some parameters, I would be grateful! Thank you!
agustinvo is offline   Reply With Quote
Old   October 30, 2015, 09:06
Dominik
dodobenq is on a distinguished road
Hey Agustín,
I want to simulate the same case. Do you have some News? Do you have improved/modified your parameters?
Kind Regards!
dodobenq is offline   Reply With Quote
Old   October 30, 2015, 12:08
Agustín Villa
Hello Dominik,
I am still dealing with the boundary conditions. I am imposing inletOutlet for temperature in the free stream region and inlet, and a zeroGradient at the outlet.
For velocity I set zeroGradient, and the pressure is now my problem. Recently I have know about fixedFluxPressure and buoyantPressure (the last one not available in 2.3.x), and I want to use them and see their effect.
In the other hand, the solver is always a pain. I have developed an incompressible solver which is not working ok at all, and there is other option: to use buoyantPimpleFoam with an incompressible configuration.
And you? How is it going on?
Old   May 18, 2022, 00:57
Chaitanya kishore
kishore208 is on a distinguished road
Hi Agustin
I am working on the same problem, but I am facing problems to give boundary conditions for pressure and velocity at inlet and outlet.
Please share the boundary conditions.
kishore208 is offline   Reply With Quote
boundary layer, boussinesq approximation, natural convection, turbulence
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
