How to include lift force for particle tracking
Old   March 19, 2015, 09:56
Default How to include lift force for particle tracking
Jeong Kim
enoch is on a distinguished road
I wanted to look at particles' tracking using icoUncoupledKinematicParcelFoam.
SaffmanMeiLiftForce was added in kinematicCloudProperties, but I think the lift dictionary was not correctly given. How can I make it work?
File Type: png Screenshot from 2015-03-19 22:40:22.png (14.7 KB, 133 views)
enoch is offline   Reply With Quote
Old   March 28, 2015, 17:17
Retired Super Moderator
Bruno Santos
Greetings Jeongho,
I hope you don't mind, I'll quote from the private message you sent me, to add some more details to this question:
Originally Posted by enoch
It seems that the bug on lift force is fixed, but I could not make it. I wanted to look at particles' tracking using icoUncoupledKinematicParcelFoam. SaffmanMeiLiftForce was added in kinematicCloudProperties. When I run icoUncoupledKinematicParcelFoam, the solver stops running. I think the lift dictionary was not correctly given. How can I make it work?
subModels
     particleForces
           sphereDrag;
           gravity;
           SaffmanMeiLiftForce;
And as you mentioned in the private message, it's explained on this post how to use "SaffmanMeiLiftForce": http://www.cfd-online.com/Forums/ope...tml#post512967 - post #9
OK, the first detail is that the bug is already fixed in OpenFOAM 2.3.1 and 2.3.x. And according to the log file, you're using 2.3.1, therefore the bug is fixed.
As for how to use "SaffmanMeiLiftForce", you will really need to study the post I mentioned: http://www.cfd-online.com/Forums/ope...tml#post512967 - post #9
Because there are at least 2 details you need, where the first one is that you are not using it correctly:
      particleForces
           sphereDrag;
           gravity;
you should instead use something like this:
    particleForces
        sphereDrag;
        gravity;
        SaffmanMeiLiftForce
            U U.air;
For the second detail, you'll have to read/study the other post
Best regards,
Bruno
Old   April 5, 2017, 02:53
Post Adding new forces in the existing solver
AJAY BHANDARI
AJAY BHANDARI is on a distinguished road
Hi all,
I think my post best fits here. I want to do particle tracking in a porous media.
Basically i want to couple the lagrangian particle tracking with the eulerian model according to the case which i have solved.
I have started with lagrangian (solid particle) and coupled it with my eulerian solver.
Now the problem is that there are only drag force, gravity and byoyancy force which are included in the lagrangian (solid particle) solver. I want to add two new forces in this
namely vander wall force and brownian motion force.
Can somebody tell the procedure or any tutorial how to add a new force in particle tracking algorithm available in openFoam 2.4.0
Or an other particle tracking algorithm available in openFoam2.4.0 which takes care of these two forces also.
Regards
Ajay
AJAY BHANDARI is offline   Reply With Quote
Old   June 26, 2019, 05:21
Nigel Bruce Khan
Nigel Bruce Khan is on a distinguished road
hello, Ajay. I am doing something similar and I want to know if you figured out how to add van der wall force to your model. If yes could you please help me. Thank you.
Nigel Bruce Khan is offline   Reply With Quote
Lift force in UDF linh nguyen Fluent UDF and Scheme Programming 1 June 24, 2014 06:56
How to include Lift Force in Eulerian Multiphase? vagaikwa FLUENT 0 April 16, 2013 18:39
The lift force coefficient in bubbly flow Kai Yan Main CFD Forum 1 November 4, 2008 14:54
Urgently Need the code of Lift force and VM force Kai Yan Main CFD Forum 0 July 16, 2008 08:07
Saffman Lift Force CFD MAN Main CFD Forum 0 November 26, 2002 19:26
