problems when using sonicFoam with subsonic inlet BC
Old   March 13, 2015, 06:50
Default problems when using sonicFoam with subsonic inlet BC
Xinguang Wang
JasonWang3 is on a distinguished road
Hi
I am using sonicFoam with a subsonic inletBC, since the top inlet in the y direction is subsonic.
pressure
top
type totalPressure;
p0 uniform 6e5;
phi phi;
rho none;
psi psi;
gamma 1.4;
temperature
type totalTemperature;
T0 uniform 300;
gamma 1.4;
velocity
top
type zeroGradient;
But when running , some errors happen like this:
--> FOAM FATAL ERROR:
request for volScalarField psi from objectRegistry region0 failed
available objects of type volScalarField are
17
thermo:mu
thermosi
K
K_0
rho
k
(1|A(U))
thermosi_0
e_0
alphat
rho_0
p
T
e
mut
epsilon
thermo:alpha
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/openfoam/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198.
Is there anyone facing the same problems?
JasonWang3 is offline   Reply With Quote
Old   June 20, 2015, 21:56
Matei Petrescu
mateiu2003k is on a distinguished road
Hi Xinguang,
I faced the same problem but in an opposite manner. Depending on the OF version keyword's values are changing. So from OF 2.1.x to OF 2.2.x for the keyword psi the value changed from psi to thermosi (my guess). The error message the you got is very similar to mine. From the choices given I recognize thermosi which I use without trouble for sonicFoam in OF 2.2.x but when I have tried it in OF 2.1.x on my old laptop it bugged and got a similar error message to yours ->
request for volScalarField thermosi from objectRegistry region0 failed
12
psi
rho
psi_0
(1|A(U))
(rho*(1|A(U)))
e_0
alpha
rho_0
p
T
e
mu
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 131.
Let me know if this fixes your problem.
Best,
Matei.
mateiu2003k is offline   Reply With Quote
Old   June 22, 2015, 05:55
Xinguang Wang
Hi Matei
I have not found how to solve this situation. Instead, I use the static pressure and temperature, and my results seem good now.
Best,
Xinguang
inlet boundary conditions for subsonic flow paulzhang Main CFD Forum 1 June 27, 2021 00:47
Laval Nozzle sonicFoam inlet and outlet bc BernhardGrieser OpenFOAM Running, Solving & CFD 10 February 16, 2017 08:45
Difficult inlet position causing problems... Roblad Phoenics 1 February 9, 2012 15:45
Problems modeling subsonic engine air inlet with flow separation TWaung CFX 2 March 29, 2009 19:42
How to set subsonic inlet with fixed Mach number QU KUN Main CFD Forum 0 September 6, 2003 10:47
