Pressure boundary condition on walls for incompressible flows
Like Tree13Likes
Old   November 5, 2016, 14:16
Default Rempfer's 2006 paper
  #21
Olie
odellar is on a distinguished road
Since starting this thread I've come across Rempfer's 2006 paper 'On Boundary Conditions For Incompressible Navier-Stokes Problems' (http://appliedmechanicsreviews.asmed...icleid=1398501) which provides some interesting and helpful insights on using the dp/dn=0 (where n is the boundary normal unit vector) pressure boundary condition.
Section 3.1 is particularly useful, and essentially explains that dp/dn=0 CAN BE CORRECT in the setting of a projection method numerical procedure (where the 'pressure' is in fact not the physical, thermodynamic quantity, but instead an 'artificial' numerical parameter), however it is in general not true for the physical, continuous (in time and space) Navier-Stokes equations.
odellar is offline   Reply With Quote
Old   November 7, 2016, 12:13
Max
murx is on a distinguished road
Thanks, that sounds helpful. I don't have a license for this journal, but I'll try to get a hold of it.
murx is offline   Reply With Quote
Old   November 8, 2016, 05:55
Blanco
Blanco is on a distinguished road
Originally Posted by murx View Post
I agree that you can link the momentum equations to the continuity equations of course. However, you are implying that du/dx is not a function of y because du/dx(y=0)= 0. And that is a false conclusion. You cannot derive the dependence of du/dx on y by saying it is zero at y=0 and the derivative of 0 is 0. du/dx will definitely change with y unless you assume a developed flow in the given example, but that's obviously not the case we are discussing here.
Nope, in my very first post about this topic I considered a steady state flow between two flat plates, whose distance between each other h(x) is constant. I argued that (u,v)=f(y) because the geometry does not change moving along the x axis. Therefore du/dx = 0 because u=u(y). But obviously this was achieved considering a simplified case, e.g. a fully developed channel flow, very far from inlet or outlet section. I've always written about simplified cases (steady state, fully developed flow, fluid at rest, etc.) in my posts...
The momentum equations I cited were simplified, that means I already left out the terms that can be omitted due to the no-slip condition.
You can drop all convective terms and all derivates along the wall because of the no-slip condition. If we stick to the example of a flat wall along the x-direction, the momentum equation in y-direction can be written:
dp/dy = my*d2v/dy2
My comment was related to the equation in x-direction, which is:
v*du/dy+dp/dx=ny*d2u/dy2
and not
0= -dp/dx + ny (d2u/dy2) (x-direction)
because du/dy is NOT zero inside the flow...-> u=u(y)
Bye
Blanco is offline   Reply With Quote
Old   November 8, 2016, 06:03
Blanco
Originally Posted by odellar View Post
Thanks for the useful reference, I will try to get that paper.
I completely agree with the statement "the 'pressure' is in fact not the physical, thermodynamic quantity, but instead an 'artificial' numerical parameter". We know, indeed, that in incompressible N-S equations the pressure is NOT a physical quantity but it's just a so-called Lagrange multiplier. Therefore is lose all its physical background and it is just a "number" to be set in some way.
If I remember correctly, that's also the reason why we could have an infinite number of solution for a particular N-S incompressible problem, if we don't set the pressure. But the specified pressure simply "shift" the solution, without affecting the other quantities.
Old   November 8, 2016, 07:46
Max
Hi Blanco, I did not mean to offend you and I appreciate your participation in this discussion. I mentioned in an earlier post that I agree with you on that for this simplified case. I just thought we were back to a more general CFD approach. However, you were of course right for the case you mentioned.
and not
Bye
Yes, du/dy is NOT zero inside the flow. I was stating the momentum equations for the wall, where we are looking for a pressure condition. Here du/dy is still not zero, but v is. And that's why you can drop the convective terms.
On another note, while looking for the article by Rempfer, I found this paper:
https://www.ljll.math.upmc.fr/pironn...s/GreshoOP.pdf
which is also interesting. This might be useful for somebody who is deeply involved in this topic, since the authors seem to disagree with Rempfer on one point.
Old   November 8, 2016, 10:25
Blanco
Hi Murx, don't worry, I'm not offended or hurt and I appreciate your comments too!
I just wanted to point out that I was still referring to simplified cases, for the sake of clarity, and that I don't have (unfortunately) any useful reference concerning more complicated cases (such as developing flow).
Ok, understood, I agree on that equation as long as we move "on the wall". Thanks for the reference on the pressure BC's for incompressible N-S equation.
Old   May 10, 2021, 10:49
Munki is on a distinguished road
Recently, i found a lecture in which the original question of this thread is discussed. This video (starting at 2:30min) might be helpful for future discussions:
https://www.youtube.com/watch?v=yWUc2D_WTMY
mikulo likes this.
Munki is offline   Reply With Quote
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
