snappyHexMesh generalization for airfoils
Old   March 7, 2015, 05:43
Question snappyHexMesh generalization for airfoils
thofst is on a distinguished road
I was trying to modify the code of the generally known tutorial on airfoils (https://www.hpc.ntnu.no/display/hpc/...l+Calculations) in order to use it for 3D stl files of different airfoils.
I am pretty new to OpenFOAM (so please forgive my stupid questions), so I tried just to replace the airfoil.stl in the snappyHexMesh/contstant/triSurface folder with my 3D model.
Unfortunately, it seems as if I need to change some other properties too. Could you help me on this?
Thanks a lot in advance!
thofst is offline   Reply With Quote
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 12:55
[snappyHexMesh] Error in SnappyHexMesh gooya_kabir OpenFOAM Meshing & Mesh Conversion 2 October 23, 2013 05:41
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 17:02
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 08:08
